4.0 in-tank fuel pump for injected yj? - JeepForum.com
post #1 of 9 Old 04-09-2013, 08:40 PM Thread Starter
flyingdeuce
1987 YJ Wrangler
I put a Mopar FI in my '87 and it was beautiful. Unfortunately had to leave it sit for a few months and now it runs great in the garage but sputters and dies on the street. I'm thinking clogged fuel pump and filter (old gas) or just a bad pump. Before I replace them as is, anyone make the swap to a 4.0 in-tank fuel pump? I've got the 20 gallon tank so wondering if I can just drop in the 4.0 pump and give it a go. Any issues, wiring challenges?
Thanks for any thoughts.
flyingdeuce is offline
post #2 of 9 Old 04-09-2013, 09:17 PM
jeep108
I was wondering the same thing as I'm about to put a zj 4.0 in my yj. Found this onhttp://www.pirate4x4.com/forum/jeep-...-write-up.html pirate, don't know if it works but would love for you to try it and let me know
Find the"YJ of the month" contest in the stickies and participate!
Eph 6:13 -Therefore put on the full armor of God, so that when the day of evil comes, you may be able to stand your ground,
Originally Posted by Opihi59 View Post
Welcome to the forum.
If you are a mechanical neophyte and have to repetitively intone the mantra of "lefty loosey," are a mouth breather and only own a hammer, it will be more of a challenge.
jeep108 is offline
post #3 of 9 Old 04-10-2013, 01:05 AM Thread Starter
flyingdeuce
1987 YJ Wrangler
Thanks for the link, but man I'm hoping it isn't that complicated. I need to call and see if I can get the specs but I'm hoping its as easy as modifying the stock harness and the additional power cable from the new efi and mating it to the stock assy for a 4.0 below. Seems like it should do the job.
http://www.jeep4x4center.com/fuel-pu...-17724-16.html
post #4 of 9 Old 04-10-2013, 06:50 AM
Que89YJ
How did you work the return fuel line. The MPFI pump is setup for a return.
Que89YJ is online now
post #5 of 9 Old 04-10-2013, 05:10 PM
idaholtby
Yes, need more info. Especially on the year/model of the Mopar FI that was used. Like Que stated, an OBD1 MPFI pump needs a return from the fuel regulator on the fuel rail. Where as a "97" plus or OBD11 setup has the regulator built into the fuel pump assy. and does not require a return line.
idaholtby is offline
post #6 of 9 Old 04-10-2013, 07:35 PM
4.7stroker
I have installed a FI pump in my stock tank, there is a return line in the 88. Just make sure the shape of your access panel. Round or square. I did have to trim 1" from the bottom of the return so it would fit in the tank. Ran some power to the pump and has not missed a beat since.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #7 of 9 Old 04-10-2013, 08:29 PM
jeep108
Dwayne
Good to know, did you use one from a yj, xj or something else?
jeep108 is offline
post #8 of 9 Old 04-10-2013, 11:00 PM Thread Starter
flyingdeuce
1987 YJ Wrangler
Dwayne
Thanks for the replies guys. It's a 258ci with stock head running the aftermarket Mopar MPI Kit (http://www.quadratec.com/products/17005_01.html) which basically makes it a '91 fuel injection. The pump, filter and regulators it on the crossmember in front of the tank and the return is to the tank as the return is eliminated with the rail. 20 gal tank with the square opening.
It has run fantastic for over a year, just thinking it'd be a good time to move the pump before vapor lock summer or hitting something.
4.7 Stroker, think the pump I listed above works or what did you use?
post #9 of 9 Old 04-11-2013, 08:21 AM
Que89YJ
So the pump has the return line on it and the pressure is regulated at the pump by an external regulator with a return line? The pdf is terrible on Quads web site and I have never seen the setup up close and personal.
fuel , injection , pump
