4.0 swap wiring - JeepForum.com
post #1 of 2 Old 07-11-2008, 02:00 AM Thread Starter
darkhawk936
4.0 swap wiring
1st post on this forum. and this is prolly covered many places elsewhere, but ive done my 4.0 swap, and its wire time. ive run into an odd problem. theres dozens of good sites about this swap, but everyone seems to favor an xj swap into a yj. ive got an 87 yj. and i swapped in a 4.0 from a 91 YJ. so i did a yj/yj swap. the best i can figure is the chassis harness is the same from 97-91. and since this is a 91 engine i SHOULD in theroy be ok. i just need to plug the fuel pump power wire into the bulkhead connector. and splice in my gauges. im hoping soneone here has done this, and can give me a lil insight. thanks .
darkhawk936 is offline
post #2 of 2 Old 07-11-2008, 02:31 AM
Jkanly
Did you previously have a 4.2 or a 2.5 in the jeep? I'm pretty sure the 87 - 90 yjs were 4.2 liter and the wiring harnesses should be the same. Its in 91 that they changed everything over to 4.0. I doubt that the fuel pump is the same
Jkanly is offline
4.0L swap - wiring help Dingleberry YJ Wrangler Technical Forum 6 09-07-2011 02:08 PM
2.5L to 4.0L swap: Wiring 101 Tomb Raider YJ Wrangler Technical Forum 17 09-30-2009 11:48 PM
PDC Wiring for 4.2 to 4.0 swap miami30141 YJ Wrangler Technical Forum 0 03-24-2008 12:30 PM
wiring for a 2.5 to 4.0 swap rustinh1 TJ Wrangler Technical Forum 2 11-03-2003 08:11 PM
4.0 swap wiring thewoodscrew YJ Wrangler Technical Forum 0 01-04-2003 04:25 AM
