4.0 Swap into '88 Wrangler - JeepForum.com
post #1 of 2 Old 07-31-2002, 08:43 AM Thread Starter
KyJeeper
I have a '88 Wrangler with 4.2 and 5 speed. My 4.2 is shot and I want to swap to a later 4.0 FI. If I buy a wrecked late 90s Cherokee will I be able to use the later engine, transmission and transfer case? What problems will I encounter? What if I choose to swap in an automatic?
If I have a complete parts vehicle I will have access to all the other parts too.
'88 Wrangler
KyJeeper is offline
post #2 of 2 Old 07-31-2002, 09:29 AM
UPnOVER
UPnOVER's Avatar
You could have a problem with the computer & map sensor. The hard parts should be fine. I you have a problem replace the map sensor.
UPnOVER is offline
Wrangler 44 swap SmashinTJs TJ Wrangler Technical Forum 7 10-02-2009 04:59 PM
Wrangler swap xxsneek805xx Wrangler General Discussion 4 07-11-2009 07:20 AM
401 wrangler swap eche981 YJ Wrangler Technical Forum 4 09-28-2007 10:02 AM
2.5 To 4.0 Swap Help 91 Wrangler DEAN062961 YJ Wrangler Technical Forum 1 05-19-2006 10:20 PM
Wrangler - 4.3 TBI swap brokeagin YJ Wrangler Technical Forum 6 05-29-2005 08:17 AM
