#2 |
not a write up but i have a bunch of photos from when I did mine people can get the general idea that the mounts do have to be cut and new ones welded in at least.
http://rides.webshots.com/album/444691195crgxlO hope that will help someone
1993 Jeep Wrangler 4.0L Tom Woods rear HD shaft D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,5" BDS, homemade greasable boomerang shackles, SS braided lines, rubicon flares, 1" prothane body lift, 35" TrXus M/T, smitty built XRC, armor and a paint job soon to come. |
#3 |
Lots of good info on these links I'll be busy reading before I make the change.
83 CJ 7 401, T18,D20, 44 front ,9inch rear,5:13 gears locked. Currently under the knife 04 Rubicon Daily Driver but trail ready. CJ of the Month Jan. 2010 www.wohva.com |
#4 |
Lots of good info
#5 |
White YJ
some more people have been asking about a 4.0 swap so i thought i would bump this back to the top. let me know if any links do not work and i will fix them.
95 White YJ 2.5L/AX-5 Stock on 31s. Ground Pounder Fab (BESRK) Front Bumper, Herculined Interior, Windshield/Front Bumper Mounted Lights, Uniden PRO 520XL Cb,Hidden Hitch Trailer Hitch, Bestop Supertop, Modified CJ7 Hardtop and CJ7 Twist Handle Full Doors (winter) |
#6 |
White YJ
i edited some stuff and added some new links. I will try and fix some of the headings for the links to make them easier to read and find.
#7 |
I'm in the process of putting a 2000 4.0 out a Cherokee in a CJ. Can't wait to do the wiring. LOL
#8 |
has anyone spelled out what the 5 to fire wires everyone is talking about are and how they are hooked up? I thought since this was already made, it would be a good place to have basic information like that.
Build Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15 WTT: 4" springs for 6" WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask |
#9 |
You need a constant 12v to the steering column. Key on 12v(ignition) Key on start (starter relay) The ignition should power your Power Distribution center relays such as the fuel pump relay which will be your 4th wire. Mine started with 4 unless I am forgetting something....I am not sure exactly how specific you need what you are asking?
#10 |
that helps. Mine is OBDII so the starter and fuel pump relays are actually grounded not energized to close but that helps. So you had to do what to send 12 volts to the steering column?
#11 |
hey. what if I used the cab and engine side of a cherokee bulkhead connector, would that make my life a little easier? Does anyone know how to remove the lock cylinder and could I replace it with my YJ one?
#12 |
where would i find information on cross referencing different year jeeps and which parts work with what
#13 |
nice
Last edited by gf70sShow; 08-31-2010 at 07:18 PM.. Reason: wrong tab in browser- my bad |
#14 |
I looked at all the threads and have done some searching and I am not finding what I need. I swaped the origonal 4.2 in my 87 YJ for a rebuilt 4.2 from an either 89 or 90. I thought is would be an easy swap. I have hooked up all of the matching connections under the hood but now I have some "extra" wires that have no place to go on the new engine. Anyone have any idea were I can see a picture or diagram of what all the connections from my YJ go to? I really appreciate any help you all could give me. If you need pictures or more detail I will be back home on Saturday and can post them at that time. Thanks again.
#15 |
thanks for this
currently looking for XJ front body parts- drv side fender and lights,bumper,grille,washer tank. I live in CT so picking up is prefered send me a PM if u have any of this stuff 1995 red YJ 5 speed low output 2.5lt |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
