4.0 problems - JeepForum.com
post #1 of 8 Old 07-12-2010, 05:35 PM Thread Starter
taterkins02
4.0 problems
my 93 wrangler 4.0, it idles fine, you can rev the guts out of it while its sitting there, but when you go down the road and the engine gets warmer it gets a hesitation then it loses power. what could be the problem? could it be the cps? and if so is there a way you can test them?
taterkins02 is offline
post #2 of 8 Old 07-12-2010, 05:38 PM
clush
must be a common issue. mine is similar, and it has gotten worse over time.
clush is offline
post #3 of 8 Old 07-12-2010, 05:40 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
How old is the cat converter? When they start to go bad they will begin to hurt high end peformance and then it just keeps getting worrse until it starts to literally choke an engine off when it gets hot. It gets progressively worse over time.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #4 of 8 Old 07-12-2010, 05:43 PM Thread Starter
taterkins02
its a hollow cat. i changed out the tps and map, and still does it, so theyre not the problem.
post #5 of 8 Old 07-12-2010, 06:32 PM
idaholtby
Check your fuel pressure at the rail and report back.
idaholtby is offline
post #6 of 8 Old 07-12-2010, 06:32 PM
Roadyy
When was the last time the fuel filter was changed?
Have you checked for codes?
You mite want to pick up a fuel pressure gauge and run it to the inside so you can monitor it while driving to see what the psi is when it starts acting up.
Roadyy is offline
post #7 of 8 Old 07-12-2010, 07:09 PM
idaholtby
Like he said ^^^
post #8 of 8 Old 07-12-2010, 08:16 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
When you changed the sensors did you dump the learned memory in the ECM? I would have.
NSG-370 Problems! Dowecheatm TJ Wrangler Technical Forum 3 08-13-2009 09:57 PM
LED Tails - problems problems problems! Zachs TJ Wrangler Technical Forum 5 07-20-2009 10:21 PM
Any Problems? LFRider TJ Wrangler Technical Forum 9 07-23-2008 10:32 PM
D44 Gear Problems, shaft problems. lazerusrm TJ Wrangler Technical Forum 7 04-09-2008 05:29 PM
Problems viking81 JK Wrangler Technical Forum 11 08-24-2007 03:06 AM
