4.0 piston size? - JeepForum.com
post #1 of 3 Old 04-24-2009, 03:18 PM Thread Starter
Lockley
4.0 piston size?
I have a 1991 4.0 with pistons marked 50. Anyone know what size this is? Thanks Dave
Lockley is offline
post #2 of 3 Old 04-24-2009, 04:23 PM
BDKR
Re: 4.0 Piston size
Typically pistons marked with a numerical like 010 or 10 are indicating they are an oversize piston,
010 for .010"
20 for .020"
.050" oversize seems larger than normal, but i am not a machinist so I can't say whether the 4.0 bores can accept that large a piston for sure.
Not a ton of info here, but HTH.
BDKR is offline
post #3 of 3 Old 04-24-2009, 05:02 PM
Opihi59
from here it gets rough
Opihi59's Avatar
98.4 mm or 3.87 inches is what I found online. Are you able to mic it and see how this corresponds to what is listed as stock specification?
http://www.allpar.com/mopar/40.html
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
piston rings mrbigglesworth YJ Wrangler Technical Forum 17 08-15-2006 12:24 PM
Hole in my piston Dave Bedell YJ Wrangler Technical Forum 2 01-21-2005 10:00 PM
Piston with a Hole DirtyRedTJ TJ Wrangler Technical Forum 13 12-15-2003 07:28 PM
4.0L Piston slap gothemi YJ Wrangler Technical Forum 1 07-21-2003 04:07 PM
Piston/Connecting Rod robuconn YJ Wrangler Technical Forum 3 07-12-2003 01:10 AM
