4.0 idles fine but can't handle load - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4.0 idles fine but can't handle load
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 10-30-2008, 01:06 PM   #1
shortstuf
Just had the engine swapped out on my YJ 4.0L. Everything was hooked up and ran it for 30 minutes according to specifications. When they took it for a drive accelerating and decelerating, again according to specs it was running great and just like new then all the sudden it started to jump and sputter and surges rpm's up and down erratically. The jeep started to act like it wasn't getting enough fuel and the last two miles it backfired and bucked like a mule, dying several times before they made it back to the shop. They ran codes Nothing, Replaced the fuel pump, cleaned the tank out and checked the fuel pressure with no luck. Timing checked and it was out 180 degrees but if set right wont even start. Change the O2 sensor, throttle position indicator, rotor and cap, spark plugs and wires, and had the cam sensor adjusted as well. Nothing. Put the timing back to 180 out and it starts, but once its under load it does the same thing. Jeep runs fine under idle, but as soon as you put it in gear and apply load all hell breaks loose. Jeep bucks, snorts, backfires, dies. Borrowed a ECU and still persisted, so they gave up on trouble shooting. Suggestions?
shortstuf is offline   Reply With Quote Quick reply to this message
Unread 10-30-2008, 02:27 PM   #2
Burnerman
A friend of mine swapped engines in his XJ and had the same trouble. He's still trying to fix it. I can't offer anything other then check every single ground wire. Did the engine you swapped in run? Did you hear it run? Have you triple checked the plug wires are properly installed and in good cond?
89' YJ Larado 4.0L,AX15
05' Grand Cherokee Limited, 2"OME lift and a Hemi.
Burnerman is offline   Reply With Quote Quick reply to this message
Unread 10-30-2008, 02:50 PM   #3
1995_4.5L Jeep
I'm not sure where you got this motor, but you might want to look at the timing chain and make sure it was installed properly. If it's a used motor it might have a stretched chain? Keep us posted
1995 Wrangler 4.5L
8.8 Ford rear
4.11 gears
ax-15 trans
4" lift 33" tires
1995_4.5L Jeep is offline   Reply With Quote Quick reply to this message
Unread 10-30-2008, 03:42 PM   #4
ghost183
you need to index and rotate the dist 180.. but you need to INDEX it
when its trying to advance the timing due to rpm and/or load, its expecting a certain cylinder to fire BTC, if the timing isnt indexed correctly, and/or off 180, its firing the wrong cylinder, it will still start and run, but will freak out when advancing
go here
http://www.angelfire.com/my/fan/dist_index.html
if anything is off, just make sure you line up the oil pump shaft, by rotating it to align it with the dist...
Important Notice:... DUE TO RECENT BUDGET CUTS, STOCK MARKET PERFORMANCE, RISING COST OF ELECTRICITY, GAS AND OIL... THE LIGHT AT THE END OF THE TUNNEL HAS BEEN TURNED OFF.... WE APOLOGIZE FOR THE INCONVENIENCE............ Regards:... THE GOVERNMENT
ghost183 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2008, 09:22 AM   #5
shortstuf
Still no luck
Tried just about everything out there. Indexing didn't help. At a total loss
Unread 01-07-2009, 11:06 AM   #6
shortstuf
I'm still having issues. Did your buddy ever figure out what the problem was with the jeep after the engine swap?
Unread 03-11-2010, 04:51 PM   #7
shortstuf
YJ idles fine but wont run under load
Well the issue was finally found. The connection at the distributor was loose, tried to pinch the connections tighter and didn't solve the problem. Finally just spliced the together and all is well. Seems the vibration and road bumps caused the short out. There was also a short in the wire going to the fuel pump. Basically, just had to perform the wiggle test on every wire there was while it was running and found the shorts one at a time.
