4.0 idle problems - JeepForum.com
post #1 of 11 Old 08-10-2008, 04:39 PM Thread Starter
pain
4.0 idle problems
I bought a 95 yj 4.0,5 speed with a burnt engine wiring harness, I put on a new harness it fired right up, I've put probably around a thousand miles on the jeep and it's run great until the other night. I was on my way home and about half way there I noticed my rpm drop and no throttle responce then it picked up and dropped again at stops it would've probably stalled if I didn't keep my foot on the gas it did this the rest of the way home. So today I pulled the throttle body off cleaned it and the IAC, same problem. I bought a new TPS and IAC and put them on and it actually seems worse, any ideas on what else it could be?
pain is offline
post #2 of 11 Old 08-10-2008, 06:41 PM
93jeepyj
Did you reset the computer after changing the tps ? I had the same issue and I changed the tps but it was still acting funny until I reset the computer, Just pull the battery cables for 30 mins or so and see if that helps
93jeepyj is offline
post #3 of 11 Old 08-11-2008, 06:21 AM Thread Starter
pain
I diddn't do that, I'll try it today.
pain is offline
post #4 of 11 Old 08-11-2008, 10:20 AM Thread Starter
pain
Well I tried disconecting the battery for a while and it's still doing the same thing, it doesn't seem as bad though. I'm going to change the feul filter tonight and see if that helps.
pain is offline
post #5 of 11 Old 08-11-2008, 11:06 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
Vacuum hoses will give you the same problems. Checkem for wear and cracking.
Tomb Raider is offline
post #6 of 11 Old 08-11-2008, 11:49 AM
1995_4.5L Jeep
CEL on? Pull the codes if so.
1995 Wrangler 4.5L
8.8 Ford rear
4.11 gears
ax-15 trans
4" lift 33" tires
1995_4.5L Jeep is offline
post #7 of 11 Old 08-11-2008, 01:26 PM Thread Starter
pain
Yea, thats my next step. When I put the new harness on I put new vac lines too so maybe something came loose.
pain is offline
post #8 of 11 Old 08-11-2008, 01:27 PM Thread Starter
pain
No, the CEL hasn't come on. It couldn't be that easy.
pain is offline
post #9 of 11 Old 08-11-2008, 07:36 PM Thread Starter
pain
Well, I changed the fuel filter still stalls, checked vac lines and couldn't find any leaks(gonna double check them again tomarrow). The map sensor and O2 sensor are all thats left I think, would either of those cause it to stall out like this?
pain is offline
post #10 of 11 Old 08-12-2008, 08:19 PM Thread Starter
pain
When I got home tonight I put a new 02 sensor on and it still died, put a new map sensor on and what do ya know the last sensor to change and it stays running!
IAC-$44
TPS-$41
02 sensor-$54
map sensor-$48
Having a Jeep that runs the way it's supposed to-Freegin priceless
Hopefully it stays that way
'95 YJ 4.0L 5-speed, SOA, 1 1/2" R.E. springs, R.E. shocks,
header,Flow Master cat back,
Poison Spider rock sliders
Full width D44 front D60 rear
38" SSRs
pain is offline
post #11 of 11 Old 08-13-2008, 06:18 PM
93jeepyj
wow I'm suprised that didnt trip a code , glad you got it running again tho
93jeepyj is offline
Big Idle Problems TheStone TJ Wrangler Technical Forum 13 11-30-2009 09:51 AM
Idle problems. RPM's low at idle. rocknjeep YJ Wrangler Technical Forum 6 08-16-2008 07:54 PM
Idle Problems....Hep me! Rabert YJ Wrangler Technical Forum 2 05-21-2007 05:58 PM
90 YJ Idle Problems cardonal70 YJ Wrangler Technical Forum 1 03-20-2004 10:32 PM
Idle problems SMehder YJ Wrangler Technical Forum 7 11-09-2003 07:59 PM
