4.0 HO Ignition upgrade - JeepForum.com
post #1 of 6 Old 08-09-2007, 01:45 PM Thread Starter
vanillacoke642
Hey guys, just a quick question for someone who knows what they're doing, Im looking at upgrading my ignition/coil and I came accross this 1
http://www.quadratec.com/products/17610_102.htm
my question aside from if you think its a good choice is that about half way down the description it links to a coil
(this coil)
http://www.quadratec.com/products/17610_200.htm
My jeep is a 1995 and the coil displayed says is compatable with 1987-1990 YJs, any clue as to why or if thats even true and if so what kind of coil upgrade do you suggest
Thanks!
vanillacoke642 is offline
post #2 of 6 Old 08-09-2007, 03:57 PM Thread Starter
vanillacoke642
no one have any ideas? -bump
post #3 of 6 Old 08-09-2007, 04:12 PM
jbolty
jbolty's Avatar
Seems like a lot of money for just a coil.
I just installed one of these last week and very happy, so far. Idles better and able to rev about 500 rpm higher without changing anything else. I still have stock carter carb (hopefull not much longer)
http://www.crtperformance.com/html/jeep_amc_hei_s.html
I have no direct experience with 4.0, since I have 4.2 but that's my 2 cents.
jbolty is offline
post #4 of 6 Old 08-09-2007, 04:15 PM Thread Starter
vanillacoke642
thanks for the input, I also thought it seemed like a lot for a coil, but I figured with the new ignition the stock coil may not be able to handle it? Just seeing if anyone thought this coil had anything to offer above other aftermarket coils and if its even compatable for 95YJ
post #5 of 6 Old 08-09-2007, 05:16 PM
bamato
bamato's Avatar
I would stick to high performance engines on that type of coil. You aren't going to see a lot of a performance hike with the stock 4.0. I thought of that as well, and after some research, realized it wasn't for me.
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Mud is your Friend :)
Tread Lightly
Please help keep our trails clean for future generations to enjoy outdoor recreation as well!
bamato is offline
post #6 of 6 Old 08-10-2007, 02:16 AM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
livewires or something like that seems to be the "best" ignition upgrade i've seen first hand on a 4.0
i think quadratec sells their system.... it's just a coil and wires perhaps? i forget..... i wouldn't waste my money on the msd box though....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
Need help with ignition upgrade OffroadAlex TJ Wrangler Technical Forum 3 04-14-2009 10:35 AM
ignition upgrade hepcat75 YJ Wrangler Technical Forum 1 02-28-2008 08:41 PM
'90 2.5L Ignition upgrade????? everyday-tan YJ Wrangler Technical Forum 1 07-18-2006 10:28 PM
ignition upgrade toates89 YJ Wrangler Technical Forum 16 06-15-2006 10:18 AM
Ignition Upgrade crushnik TJ Wrangler Technical Forum 1 04-13-2003 12:48 PM
