Quantcast 4.0 Head Swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4.0 Head Swap
Old 05-30-2008, 09:15 PM   #1
Douglas S.
1987 YJ Wrangler
4.0 Head Swap
I was sort of forced into this because of a burnt valve in my original cylinder head and while i was in there i decided to paint the motor and manifolds. This is what it turned out like:
Before,
After,
1991 Land Cruiser HDJ81- 1HD-T Turbo Diesel, Factory F/R Selectable Lockers, Warn M8274, Webasto Thermo 90S
1987 YJ Laredo
Douglas S. is offline   Reply With Quote
Old 07-15-2008, 06:14 PM   #2
Ironman23
1987 YJ Wrangler
damn looks clean! is that just engine block rattle can you used for the manifolds? How hard was the swap?
Ironman23 is offline   Reply With Quote
Old 07-15-2008, 06:56 PM   #3
NJeepyj91
Very nice work.
She's going to bury me in this thing.
91 4.0 stick. Posi Lok, Borla, 31s on steelies, Dem Bonz Shackles and lots of other junk on my junk.
NJeepyj91 is offline   Reply With Quote
Old 07-16-2008, 06:47 AM   #4
roadyrob
1987 YJ Wrangler
X2 on the nice work! a couple of questions, which header did you use? 4.2 or 4.0 push rods? is the 4.2 manifold a direct bolt on? a finally, do you feel you got the extra 40 HP they claim?
roadyrob is offline   Reply With Quote
Old 09-02-2008, 05:38 PM   #5
Douglas S.
1987 YJ Wrangler
I used the header from the 4.0
I had to use some shims to get the 4.2 manifold to line up
I felt a huge power increase
1987 YJ Laredo
Old 09-02-2008, 06:04 PM   #6
Xzero117
awesome man
I'm planning to do the same thing
the ignition system and weber just isn't giving me enough power
http://i173.photobucket.com/albums/w66/xzero117/jeep060.jpg
Xzero117 is offline   Reply With Quote
Old 09-02-2008, 08:22 PM   #7
Douglas S.
1987 YJ Wrangler
Originally Posted by Xzero117 View Post
awesome man
click free.......
1987 YJ Laredo
Old 09-02-2008, 08:27 PM   #8
sitdwnandhngon
1987 YJ Wrangler
How long did it take you and where did you use a donor head or did you get a new one?
I can't bear the thought of losing, I dread the attention winning brings
Originally Posted by northjeep View Post
4.2 has 0.2 more!
sitdwnandhngon is offline   Reply With Quote
Old 09-02-2008, 09:05 PM   #9
YJSos
I have been thinking about doing that to mine lately. The paint looks awesome!!! My problem with the 4.0 head swap is I have a borla header for the 4.2 and that might make it too expensive.
Josh
"My Jeep Is Like A Bum, Always Begging For Change"
1989 YJ Patiently awaiting its new frame....
2001 Toyota Tacoma Double Cab TRD trying to keep it stock but its not working
YJSos is offline   Reply With Quote
Old 09-02-2008, 11:32 PM   #10
themonkeyman
1987 YJ Wrangler
Looks awesome man! Were you able to paint it like that in the jeep? Impressive results either way. I'm guessing the 4.0 valvecover is used as well? Oh, and what about studs? just re-use the stockers? or get upgrades?
*edit*
I'm looking into doing this too, but like you, I will be retaining my Mc2100 carb. What do you mean by "shims" to line up the manifold? I don't see anything... also, does your motor now rev to 6k or whatever the 4.0's redline at? Thanks for any info, it's much appreciated...
themonkeyman is offline   Reply With Quote
Old 02-16-2009, 09:21 PM   #11
Douglas S.
1987 YJ Wrangler
Got a donor head from a cherokee. Then had it redone.
1987 YJ Laredo
Old 02-16-2009, 09:23 PM   #12
Douglas S.
1987 YJ Wrangler
*edit*
I guess shims wasn't a great word to use. I had to double up the washers on the bolts in a couple places. It worked, no issues so far.
I haven't tried to rev it up, I don't think the bottom end is up to it. There isn't really a need to. It revs more freely now than it did before.
1987 YJ Laredo
Old 02-17-2009, 10:32 AM   #13
parrot5254
if you don't mind me asking roughly how much $ do you have in this swap. I really want to do this swap I just don't know if I have the funds right now.
Orange 1987 YJ - Deceased
Red 1996 Cherokee Sport - DD (soon to be lifted and locked)
parrot5254 is offline   Reply With Quote
Old 02-17-2009, 10:41 AM   #14
Douglas S.
1987 YJ Wrangler
The only major cost is redoing the cylinder head before I put it on. You don't have to do this though. If the head you grab is in good shape, then this swap can be done very inexpensively. Grab the head and header from the donor, get a gasket kit, and install.
1987 YJ Laredo
Old 02-22-2009, 10:27 PM   #15
kmedd3
nice work
Nice! Couple of questions, which push rods did you use, 4.2 or 4.0? Which head bolts?
thnks
keith
kmedd3 is offline   Reply With Quote
Glock Forum
