4.0 Head Swap on 4.2 Thoughts? - JeepForum.com
 2Likes
post #1 of 16 Old 09-25-2017, 08:26 AM Thread Starter
TX-YJ
Good Morning Everyone!
I need to replace the head on my 4.2 '90 YJ and have previously read about replacing the head with a 4.0 head and at the same time replacing the intake and switching it from carbed to FI. I am still pretty new to a lot of this and am currently running a 4.2 with a 2150 carb. Most of the links in the FAQs are dead, and was curious if anyone knew of a good write-up still alive out there somewhere. Also, what are your thoughts on the 4.0 Head Swap with FI vs. 4.2 with a 2150 carb? Would the difference be worth the work?
Thx in advance!
TX-YJ is offline
post #2 of 16 Old 09-25-2017, 08:43 AM
jserna
1987 YJ Wrangler
Yes the differences are well worth the work. I swapped in FI in my 87 about 15 years ago. The single best mod I made. The power difference is pretty significate.
jserna is offline
post #3 of 16 Old 09-25-2017, 10:21 AM
mike134
You get a big peak horsepower boost going with the newer technology head.
The FI will broaden your HP curve and make you feel like you have a ton more horsepower when you are off peak.
No disadvantages, except that some EPA jurisdictions might prohibit it if you are a resident in one (Los Angeles for example)
mike134 is offline
post #4 of 16 Old 09-25-2017, 10:55 AM Thread Starter
TX-YJ
Awesome, planning on tackling this project in the coming weeks. Thanks for the responses. Would you opt for a clearwater head or try to find a junkyard 7120? Is there any specific model year that is best to try and pull a 7120 and related parts from?
TX-YJ is offline
post #5 of 16 Old 09-25-2017, 11:01 AM
mike134
Is the head already modified for your 4.2L if you buy it?
If not, you may as well get one from the junk yard, because you might mess up the welding of the coolant ports.
mike134 is offline
post #6 of 16 Old 09-25-2017, 12:57 PM
Beach248
I've never done this swap, but I thought you just had to epoxy the coolant ports, not weld them? I remember something about stuffing packing peanuts in there and epoxying over the peanuts, and the peanuts melt away later because they are biodegradable......
nyyj1989 likes this.
88' YJ, 4.2, Howell EFI, CRT HEI, 8.8 4:10, 95' D30, AX15 ex. slave, Dodge NP231 wide chain
Beach248 is online now
post #7 of 16 Old 09-25-2017, 02:25 PM
mike134
People have been successful with "JB weld" epoxy. A real metal weld is better though.
The risk with the epoxy is if a chunk pops off and ends up floating around the coolant system, its bound to cause a major issue.
I won't discourage it or anything, but make sure you have REALLY good adherence of metal to epoxy.
mike134 is offline
post #8 of 16 Old 09-25-2017, 06:03 PM
shaggyjim
shaggyjim's Avatar
It might be better to have freeze plugs installed instead of epoxy or welding.
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #9 of 16 Old 09-25-2017, 06:12 PM
nyyj1989
I did this swap almost 17 years ago. I did not use JB Weld but something similar.
It was from a marine store and it's two part epoxy called Marine-Tex.
make sure you get "packing peanuts" that dissolve.
I have had zero issues.
I did the head swap and FI at the same time.
I am very happy with it. The engine is running strong all these years later.
Hope that helps.
nyyj1989 is offline
post #10 of 16 Old 09-26-2017, 12:00 AM
lclark2074
lclark2074's Avatar
I did mine about 8 years ago and i would not go back. jbweld works good for me too. Its only freeze plug pressure on the jbweld so it works good. Go to your local pic and pull and get the wiring harness, intake, fuel rail,exhaust factory header,charcoal canister and computer.
night crew 226
lclark2074 is online now
post #11 of 16 Old 09-26-2017, 05:31 AM Thread Starter
TX-YJ
Thanks again for the feedback guys. Iclark, is there a specific cherokee year that I should try to find to pull the parts from? I thought i read somehwhere that the 1996 models had stronger parts than the earlier years.. any truth to that?
TX-YJ is offline
post #12 of 16 Old 09-29-2017, 10:59 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Get one from a 91-95 with the 7120 cast head. Or a 96-99 with 0630 avoid the 00-01 with 0331 heads that crack.
When i did a cam swap and replaced all the seals i was going to swap on a 7120 head (its on my toolbench) but i didnt do it to save money since i could never get a definitive answer on pushrods. Then i screwed up and left a rag in the oilpan. So my 258 got trashed. Now im almost done with my 4.0l swap
'89 YJ The Smurf Yjoty 2016
'99 XJ Black Betty
Tom95YJ is offline
post #13 of 16 Old 09-30-2017, 12:09 AM
lclark2074
lclark2074's Avatar
like the previous poster seas 1991-1995 will work. Pull all the hardware off. But the intake off 2001 will flow better than an obd1
you may like this thread for help
JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4.2L Fuel Injection and Build
night crew 226
post #14 of 16 Old 09-30-2017, 09:01 AM
Beach248
Quick question, will a 4.2 intake manifold work on the 4.0 head? I already have a Howell FI on my 4.2, so I'd rather just use that, since i'm in California, and have my Howell CARB sticker.
EDIT: For anyone wanting to do this, or run a carb, I found out that the 4.2 intake will work on the 4.0
post #15 of 16 Old 10-01-2017, 12:38 PM
timatoe
timatoe's Avatar
EDIT: For anyone wanting to do this, or run a carb, I found out that the 4.s intake will work on the 4.0
I've been hesitant to do this for the same reasons.
Hope you do a write up when you get to it.
Beach248 likes this.
timatoe is offline
