4.0 HEAD ON A 4.2 BLOCK? - JeepForum.com
post #1 of 5 Old 07-05-2002, 04:17 PM Thread Starter
MANTHING
I TRIED TO PUT A '91 CHEROKEE HEAD ON MY '87 YJ AND THE EXHAUST DOES NOT LINE UP RIGHT.EVEN WORSE IS THE INTAKE DOES NOT MATCH AND NEITHER TYPE OF GASKET MATCHES UP.NOW ALL THE ARTICLES I'VE READ SAY THAT THIS SHOULD BE AN EASY ENOUGH SWAP BUT NOW MY JEEP IS SITTING CUZ I DON'T WANT TO PUT THE 4.2 BACK ON.HAS ANYONE HAD THIS PROBLEM AND WHAT DO I NEED TO DO TO FIX IT?
LITTLE NOTE HERE:THE '87 IS THE WRONG YEAR TO BUY IF YOU WANT TO DO ANY MODS.YOU SHOULD HAVE SEEN MY TRANNY SWAP. AAAAAAAAAAAAAAGGGGGHHHHH!
MANTHING is offline
post #2 of 5 Old 07-06-2002, 07:07 AM
lostboy
you need the exhaust manifold for a 4.0 head.Try this <a href="http://www.monsterslayer.com/jeep/40Head/40Head.htm" target="_blank">http://www.monsterslayer.com/jeep/40Head/40Head.htm</a>
89 yj w/ mopar mpi and 4.0 head.94 ax-15 tranny and t-case, more mods comin.
lostboy is offline
post #3 of 5 Old 07-06-2002, 07:57 AM
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
You also need to stop typing with caps on. Its not easy on the eyes and annoys alot of people to the point that they dont want to even respond to your posts.
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #4 of 5 Old 07-06-2002, 10:20 AM Thread Starter
MANTHING
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by lostboy:
<strong>you need the exhaust manifold for a 4.0 head.Try this <a href="http://www.monsterslayer.com/jeep/40Head/40Head.htm" target="_blank">http://www.monsterslayer.com/jeep/40Head/40Head.htm</a></strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">the manifold came from a 91 cherokee with a 4.0,it ports out the end not in the middle like a wrangler.guess i need one from a wrangler only.
i read that article & it doesn't say they don,t match from a cherokee
MANTHING is offline
post #5 of 5 Old 07-06-2002, 10:41 PM
lostboy
well.I tried a manifold from an 87-90 4.0 and it bolted up fine to the engine,but I didn't want to haul it to an exhaust shop to fabricate the downpipe..so I ended up gettin a borla header....I love the setup...If you don't want that expense,you can have a downpipe done by a shop for a lot less.
lostboy is offline
4.0 Head 4.2 Block questions blue89wrangler YJ Wrangler Technical Forum 4 09-29-2009 10:01 AM
4.2 block with 4.0 head conversion ersala89 YJ Wrangler Technical Forum 2 07-24-2009 12:55 PM
YJ head on a CJ block? Felonious_monk YJ Wrangler Technical Forum 5 06-09-2008 09:33 PM
4.0L Head on a 4.2L Block?? atomicmoose YJ Wrangler Technical Forum 16 01-17-2005 12:25 PM
Oil leaking between head and block gfreel YJ Wrangler Technical Forum 3 01-16-2005 06:24 AM
