4.0 Fuel injection swap on a 4.2. - JeepForum.com
post #1 of 11 Old 09-09-2009, 05:37 AM Thread Starter
wilson101
I looked into the FAQ and saw alot of engine swaps and alot of heads swaps.
But i was wondering if it possible to just swap the 4.0 head, fuel injected intake manifold along with all the ecu and wiring harness onto a 4.2 engine.
My only concern is will the distributor from a 4.0 will fit the 4.2 block, since im guessing its what houses the crank angle sensor.
I could compensate for the extra .2 liters by crushing the FPR alittle bit to increase the fuel pressure until i get to the right AFR.
If you havent figured it out i drive a 1988 4.2 L Wrangler
Thanks
wilson101 is offline
post #2 of 11 Old 09-09-2009, 08:22 AM
93jeepyj
What you want to do is very common and absolutly possible. the distributor will drop right in and you may not even have to mess with the fuel pressure.
93jeepyj is offline
post #3 of 11 Old 09-09-2009, 09:23 AM
cbrseadude
You shouldnt have to mess with the fuel pressure like that, it will be close enough. Im looking to do this also, looks like the only special things you need are the front damper and crank sensor mount which is available from several places.
cbrseadude is offline
post #4 of 11 Old 09-09-2009, 10:02 AM Thread Starter
wilson101
Front damper? What is that?
Thanks for the info guys.
post #5 of 11 Old 09-09-2009, 10:17 AM
deerslayer123
Wilson, your still gonna need several more parts for that swap. Keep researching. your still gonna need the exhaust manifold, flywheel, 02 sensor, map sensor,etc.. Search for a head off 91-95 as they say it the best head for the swap. It has 7120 cast on the head. There's lot of good info out here and if you google it. Here's a link to a guy hwo did the exact swap you want with parts list and pictures.
Jeep Strokers • 4.0 head and EFI on a 4.2 block
Good luck!!
deerslayer123 is offline
post #6 of 11 Old 09-09-2009, 10:33 AM
cbrseadude
What i mean by special is, parts you cant pirate off of a production vehicle in a junk yard or a vehicle someone is parting out. The damper or dampner, depending on who your are talking to is on the front of the crankshaft, the specialized one allows for a crank sensor to read off of it instead of messing with flywheels and stuff like that. If you google and look, you will find that you really dont need alot of specialized parts, just a few, the rest is production parts that there are tons off out there.
post #7 of 11 Old 09-09-2009, 11:06 AM Thread Starter
wilson101
Good luck!!
Thanks Deerslayer thats exactly what I was looking for. I guess i'll be hitting the junkyard in the next few days.
post #8 of 11 Old 10-12-2009, 04:37 PM
poppatello
What is the point of swapping the head on a 4.2 to a 4.0? I would think the 4.2 head is better...
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #9 of 11 Old 10-12-2009, 07:06 PM
ElvisV04290
ElvisV04290's Avatar
The 4.2's head has intake ports at a 90 degree angle, while the H.O. 4.0s head has intake ports at ~45 degree angle. What this adds up to is the 4.0 head breaths better and increases engine efficiency, so you get a boost in HP and TQ.
1990 YJ, Colorado Red with 'Laredo' markings, 4.2L, TF999, NP231, Valvoline Syn fluids, Weber 32/36, Nutter Bypass, Dana 30/35, 16" Electric Fan, Optima Yellow Top, 140amp alt., K&N Air Filter, Cherry Bomb muffler, SRC Front Bumper, CH&F Shackles, KC 100w Daylighters, Homemade Lightbar, Rear Aux lights, Cobra CB/PA/WX, 102" Whip Ant., 400 watt power inverter, 2 fire extinguishers, Mobile Internet & WiFi equipped.
Daily Driver since April 23rd, 2003
Northern Illinois Extreme Jeep Club Member
Weber 32/36 Install ->
Early YJ Club Member #37
For anyone with a 4.2L -->
ElvisV04290 is offline
post #10 of 11 Old 10-12-2009, 08:04 PM
poppatello
what is the difference in the HP and torque?
Paved Roads
post #11 of 11 Old 10-12-2009, 09:56 PM
Douglas S.
Signifigant, I've heard as much as 50hp, not sure about torque
1991 Land Cruiser HDJ81
Douglas S. is offline
4.2L to 4.0L Fuel Injection Swap? wannagojeepn YJ Wrangler Technical Forum 5 02-08-2015 12:25 PM
4.0, 4.2 head swap with fuel injection???? Redbird89 YJ Wrangler Technical Forum 5 11-26-2009 04:27 PM
Should I swap in Fuel Injection in my 88? Ben_88Jeep YJ Wrangler Technical Forum 16 02-06-2009 02:18 PM
Fuel injection swap for 4.2L Ares YJ Wrangler Technical Forum 3 09-19-2006 08:02 AM
4.2L carb to 4.0L Fuel Injection SWAP shawnmiller75 YJ Wrangler Technical Forum 1 03-20-2006 10:36 PM
