4.0 Fuel injection on 4.2 - JeepForum.com
post #1 of 47 Old 07-15-2007, 01:48 PM Thread Starter
IJP2
I thought I saw a write-up on doing a 4.0 injection swap on a 4.2. Does any body know if this is possible. I thought that doing it required re-tapping the head so that you can swap the intake manifold with the 4.0's. But I may be confusing this with something else. Any help would be appreciated. I tried doing a search on this and looked in the FAQ but no luck.
IJP2 is offline
post #2 of 47 Old 07-15-2007, 02:06 PM
goatboy
I put the Mopar kit on my 4.2, however, it contained a new manifold...essentially, it is the FI from a 1994-95 4.0...if the heads are different, you might be able to source a manifold only from Hesco, who makes the Mopar kit...
goatboy is offline
post #3 of 47 Old 07-16-2007, 12:15 PM Thread Starter
IJP2
Sounds like an idea. How much was everything? Was it pretty easy install
IJP2 is offline
post #4 of 47 Old 07-16-2007, 02:15 PM
Prowler
I've currently got a fuel injected 4.2 in my Jeep. The shortblock was out of an 88 XJ and I took the head/intake from my 4.0 and put it all on the 4.2, I only had to do a few minor mods to make it work. Just fill the water jackets in the head to make it go on the 4.2 I also had to cut the front of my crank a lil bit to get the serpentine pulleys on it and made a lile bracket for my coil to bolt to and cover the mecch fuel pump hole. Other then that, run awesome and gobs of torque down low.
4.2 EFI - Pacesetter header - Flowmaster - 4.5" RE XD - RE Monotubes - 35" Trxus M/Ts - 4.10s - D30 Aussie - 8.8 Trac Lok - NV3550 - Centerforce Dual Friction - B&M Shifter - ARB Snorkel - Livewires - M8000 - Duralined interior - custon front bumper - custom brush cables - HiLift on the hood with lights
"Don't follow me, You won't make it!"
Prowler is offline
post #5 of 47 Old 07-16-2007, 02:46 PM
northjeep
Jeep parking ONLY
northjeep's Avatar
go to the junk yard
get a 4.0 head and everything to the TB. I mean everything...injectors, fuel rail, FPR, the works.
Then find yourself a good programmable after-market computer and even fire Electronic ignition.
I suggest S.D.S. EFI. ( http://www.sdsefi.com ) Great computers...really reasonable prices. The EM-4 F is an all in one ignition and EFI unit.
If you dont want to go to all that length:
Junk yard source the 4.0 intake, injectors, fuel rail + FPR, TB and wiring harnes.
Yank the computer and make the conversion.
you will need a new gasket set and will have to grind the alternator mount on the intake manifold to make it fit in the 4.2 application...
I highly recommend going Electronic Ignition.
-NorthJeep - >> Just Enough Essential Parts
northjeep is offline
post #6 of 47 Old 07-17-2007, 07:16 AM Thread Starter
IJP2
Wow, it doesn't sound as complicated as i thought it might be to make it work. You know I do remember reading something about filling in the water jackets. Man i wish I could find that thread. It was a whole right-up on it. I will start looking around the junk yards and begin collecting my parts. Oh one more thing. I have to pass the smog test one last time. There is a new clause that states that any vehicle that was made before 95' no longer has to do the test, but it must first have passed it before the end of 05'. I was In the Air Force and stationed in North Dakota When i bought the YJ in Illinois but since i was stationed out-side of the state i got a waiver. But now that I am back I have to pass one last time. So my question is,(finally I know, LOL) would I be able to pass the smog test with this conversion. I would think I would since its more efficient.
IJP2 is offline
post #7 of 47 Old 07-17-2007, 10:04 AM
TommyT
1987 YJ Wrangler
I just installed a 4.0 MPI...
...on my '87 Wrangler. Then I took it to the Smog Check station. Passed with fly'n colors. If it'll pass here in SoCal, it'll pass anywhere. Just make sure you get EVERYTHING from the donor car...charcoal canister, thermostat housing with coolant temp sensor...everything...and hook it up properly. Sounds intimidating but it's easy.
TommyT
TommyT is offline
post #8 of 47 Old 07-17-2007, 02:43 PM
Prowler
Heres what I came up with for when I did the swap on mine. Hope it helps
http://jeep.off-road.com/jeep/articl....jsp?id=277013
Prowler is offline
post #9 of 47 Old 07-17-2007, 11:03 PM
goatboy
Regarding my Mopar installation, it was not brain surgery, but it was a pretty involved installation... It was a kit, so it was a lot different than you goin out and sourcing an FI from a junkyard or whatever...the kit was very complete, but I would not recommend it to a novice mechanic...
goatboy is offline
post #10 of 47 Old 07-19-2007, 09:32 AM Thread Starter
IJP2
Thanks Prowler, That helps out allot. Now I have to make sure I get everything I need. Like the charcoal canister and thermostat housing that TommyT mentioned. I am going to make sure i have every last thing, because I hate running back and forth. Thanks for all your guys help.
IJP2 is offline
post #11 of 47 Old 07-19-2007, 10:41 AM
jbolty
jbolty's Avatar
Were there any issues with the smog? Visual inspection issues? Did you have to go to the referee? I have been thinking about the howell tbi, since it is CARB approved, but I like the junkyard option better if it's possible. Do you have any details of what it cost and the steps?
jbolty is offline
post #12 of 47 Old 07-19-2007, 04:46 PM
Douglas S.
Here's a write-up www.jeepforum.com/forum/showthread.php?t=356768
1991 Land Cruiser HDJ81
Douglas S. is offline
post #13 of 47 Old 07-19-2007, 04:53 PM
jbolty
jbolty's Avatar
Thanks. Looks like the classic trade off of time vs money.
BUT the main concern for me is still California smog. When I was getting mine done a few weeks ago I saw the guy before me get failed for having a non-standard air cleaner and a locking gas cap.
jbolty is offline
post #14 of 47 Old 07-19-2007, 05:11 PM
Douglas S.
It should be fine considering its stock equipment on an xj
post #15 of 47 Old 07-19-2007, 05:54 PM
schwim
Hi there guys,
Anyone done the head conversion, keeping it carbureted, and if so, what was the performance increase like, if any?
thanks,
json
BOUGHT. Not Built.
schwim is offline
Fuel/air mixture adjustment on fuel injection scbasspro YJ Wrangler Technical Forum 2 06-17-2009 02:53 PM
Fuel Injection kit for 4.2l -87 Mickesweden YJ Wrangler Technical Forum 6 11-21-2007 07:19 PM
2.5 Fuel injection on a 4.2? funJ YJ Wrangler Technical Forum 1 10-27-2005 03:23 AM
Fuel Injection help funJ YJ Wrangler Technical Forum 2 09-26-2005 04:29 PM
Fuel Injection from an XJ birdman86 YJ Wrangler Technical Forum 3 08-12-2005 04:13 PM
