4.0 Electronic Ignition on 258 - JeepForum.com
post #1 of 4 Old 03-28-2002, 12:24 PM Thread Starter
CF
Will an electronic ignition system from a 4.0 work on a 258?
I know I can get the Juice Box for about $130 but I’m on a tight budget here and if I can save a few bucks using salvaged parts I’d rather do that.
Thanks,
CF
94' XJ - 3"lift, 31s
CF is offline
post #2 of 4 Old 03-28-2002, 12:34 PM
Jeepguy3401
$130 is actually pretty cheap.How much more limited can you get with a jeep.(Just Empty Each Pocket) I just picked my jeep up today from having a new flywheel and ring gear put in for $450. (Be glad you didn't have to put all that money in for not even an upgraded part). Noticed you owned an 87 though, see if you can answer some of my questions. Hey do you still have the stock carb in yours? BTW Funkytown, CA lol...
'87 YJ,4.2L 6cyl(rebuilding someday) On 33" Mickey Thompson Baja Claws, (unlifted, but big lift in store, when I get some $$$)upgraded clutch and brakes, broken loud stereo.(Can't imagine how that....COUGH!..WATER....happened. Haven't used a top doors or windshield in uh,.....hmm.... since midwinter? That sounds right.
Jeepguy3401 is offline
post #3 of 4 Old 03-28-2002, 10:32 PM
Mr. Mopar
i dont think so you can use the parts off the 4.0 because that ignition system works with the jeps computer.
major work done on a 4.0
KEEP IT JEEP!!!!!!!!!!
Mr. Mopar is offline
post #4 of 4 Old 03-29-2002, 12:54 PM Thread Starter
CF
Hey Jeepguy,
The Jeep sees the red line with no problem so I’m not willing to plunk down $130. but if I come across a good HEI distributor that will work while scouring the junkyards I’ll do it.
I just took up skiing and it’s getting expensive. (Good thing I started towards the end of the year.) I just spent $230 on a Thuele box. Cause ya can’t fit me, three chicks, their luggage, and skis etc. in a Wrangler. And I’ll need new tires next winter. What’s that gonna be after mounting, balancing and alignment, another $450?
I’m also building a EFI 5.0HO for my 67’ Mustang. Gonna mate it w/an AOD. With the increased power I’ll need to upgrade suspension and braking etc. This is why I’m on such a tight budget. The 5.0/AOD conversion is eating up the car funds big time.
It’d be cool to do a 5.0/T5 on the jeep.
oh yeah, its the stock carb (i think)
Mr.Mopar, (4.0 ignit uses computer.) Good point. I wonder if it can be bypassed. does is not use vacuum for timing adavance?
CF is offline
ignition randomly turns on after jeep is turned off and ignition locked karthac YJ Wrangler Technical Forum 3 01-12-2010 08:35 PM
Electronic(ignition) control module location 87 yj square87 YJ Wrangler Technical Forum 2 10-08-2009 09:12 PM
Epic Ignition Battle (replaced everything but the ignition switch!) thechadwick YJ Wrangler Technical Forum 10 08-27-2009 11:02 PM
Questions about ignition wires and other ignition stuff Fernando YJ Wrangler Technical Forum 10 08-11-2009 05:33 PM
Electronic ignition for a 2.5l? ZonaWrangler YJ Wrangler Technical Forum 1 11-26-2004 06:17 AM
