4.0 cranks but won't start in cold - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4.0 cranks but won't start in cold
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 01-16-2009, 04:11 PM   #1
turkman182
1992 FSJ Cherokee
Have a 1992 Cherokee that has no power to the coil. Check the obvious things but running out of ideas. It does start in warmer temperatures though.
turkman182 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2009, 06:27 PM   #2
beano
i would guess that your ecu isnt powering up seeing i have the same issue. can you hear the fuel pump start up? (not sure if its possible to hear in a cherokee seeing i have a wrangler) if you cant hear it, then your ecu hasnt powered up yet.
beano is offline   Reply With Quote Quick reply to this message
