4.0 cranks but won't start in cold - JeepForum.com
post #1 of 2 Old 01-16-2009, 03:11 PM Thread Starter
turkman182
1992 FSJ Cherokee
Have a 1992 Cherokee that has no power to the coil. Check the obvious things but running out of ideas. It does start in warmer temperatures though.
turkman182 is offline
post #2 of 2 Old 01-16-2009, 05:27 PM
beano
i would guess that your ecu isnt powering up seeing i have the same issue. can you hear the fuel pump start up? (not sure if its possible to hear in a cherokee seeing i have a wrangler) if you cant hear it, then your ecu hasnt powered up yet.
beano is offline
91+ Hard or No Start/Long cranks in the cold explained sentinal02 YJ Wrangler Technical Forum 72 04-09-2017 11:04 AM
Cranks and Cranks, cranks some more and she wont start. crzylgzz YJ Wrangler Technical Forum 37 12-09-2011 03:44 PM
2.5 cranks but wont start...Cold start SnowdogMarc YJ Wrangler Technical Forum 4 08-04-2009 07:16 PM
TJ only cranks when engine is cold wncjeeper TJ Wrangler Technical Forum 7 02-13-2009 02:51 AM
My Jeep Cranks And Cranks But No Start!!! b1ack2tar YJ Wrangler Technical Forum 5 01-14-2009 08:23 AM
