4.0 clutch on 4.2 flywheel - JeepForum.com
post #1 of 5 Old 02-24-2010, 12:04 AM Thread Starter
rdj59
1987 YJ Wrangler
Hi, Clutch went out on my 87 YJ with the BA10 and am swapping in a 95 ax15/231 in its place. Can i order a clutch kit for a 95 YJ and have the clutch pressure plate bolt up to the 4.2 flywheel? Are the clutches the same with the only difference is one comes with the hydraulic to bearing and the other has a std to bearing?
Thanks,
Jeramie
rdj59 is offline
post #2 of 5 Old 02-24-2010, 12:13 AM
Douglas S.
I bought a clutch kit for a 97 (I swapped in a 97 trans) at Napa when I did my swap (very recently). It worked perfectly. The clutch and pressure plate are identical in both kits, it's the throwout bearing and slave that change.
Is the 95 external slave?
1991 Land Cruiser HDJ81
Douglas S. is offline
post #3 of 5 Old 02-24-2010, 10:18 AM Thread Starter
rdj59
1987 YJ Wrangler
Yes it is. It's out of a 95 XJ. Just have to reclock the tcase and i'm ready for the swap.
Thanks,
Jeramie
rdj59 is offline
post #4 of 5 Old 02-24-2010, 11:39 AM
RikRotorhead
Order the kit for the newer tranny.
Be sure to change out the pilot bearing. They are different sizes for the tow trannys. The clutch kit comes with it.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #5 of 5 Old 02-24-2010, 01:39 PM
Douglas S.
The pilot bearing in the kit likely will not fit his engine. The 4.0 and 4.2 have different sizes IIRC (pilot bearing O.D.). There is also a difference in the I.D. on the external and internal slave transmissions.
I ended up turning down my own from a piece of oilite bronze, none of the parts places near me could get the proper CJ one.
installing a used clutch and flywheel? evoGibson Wrangler General Discussion 10 02-10-2010 07:19 AM
Clutch & Flywheel Problems duha TJ Wrangler Technical Forum 10 03-31-2009 08:03 PM
New Flywheel with New Clutch?? Will91YJ YJ Wrangler Technical Forum 7 10-15-2008 05:13 PM
Clutch Kit and Flywheel question? foyboyusc YJ Wrangler Technical Forum 3 06-03-2008 05:25 PM
clutch and flywheel sasquachYJ YJ Wrangler Technical Forum 13 01-17-2008 10:59 PM
