#1 | |
4.0 Build or 350 swap?
My block has 213K on it and runs pretty well BUT I am contemplating spending the winter doing a garage build.
Looking for 200 4whp at minimum. Any real thoughts as to why a swap to a SBC would be a bad idea? It appears that the swap would definitely be more costly. If anyone has experience give me some insight please.
Looking for a Jeep again... I just can't stay away |
#2 |
Since your Jeep is EFI I'd say stick with the 4.0.
Engine swaps are always more money than you expect. Price it out and double it. That's if you want it to work and don't want to have issues like overheating, breaking downstream parts, etc., etc. I'm not a purist by any stretch, I just think that the EFI 4.0s were pretty decent engines and worth keeping. The carbed 4.2 on the other hand are not my thing. I'm going to swap a SBC into mine (mainly because I have a fresh one lying around). |
#3 |
I've been on the internet too much lately. Now, even I'm beginning to think that "breaks" are what you use to stop your Jeep. |
#4 |
There's more to a 350 swap than just replacing the motor. Unless you plan on upgrading the rear axle, I'd stick with the 4.0. The dana 35 won't last with a 350, and most likely the universal joints won't either.
"Energizer Bunny arrested, charged with battery" - Jay Leno l _____ /l ,[____], l---L –0lllllll0- ()_)-()_)--o-)_) ~ Do it right or don't do it at all ~ |
#5 |
Why do you need a certain amount of HP? I can build you a 4 banger with that power easy. Also where do you want this power to come on at? 2500rpm or 5000rpm? If you a sand runner you will need it up high, and same goes for trail riding you want it in the lower rpm. I personnel dont care for a motor that is overly heavy. Some of the newer V8 engines with composite intakes and aluminum heads or better yet complete aluminum blocks, would be what I want. I have built race cars for more that 14 years and I always go for the lightest stuff I can fine that will do the job reliability.
I only read the pictures. |
#6 | |
just be careful though, and get it sleeved well, because they tend to like to crack blocks (just happened to my Dad with his 5.0 land rover)
1991 Land Cruiser HDJ81- 1HD-T Turbo Diesel, Factory F/R Selectable Lockers, Warn M8274, Webasto Thermo 90S 1987 YJ Laredo |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
