4.0 blowby question... - JeepForum.com
post #1 of 4 Old 06-18-2013, 02:20 PM Thread Starter
geusey
First of all, this isn't just another "why is there oil in my air filter?" thread.
I've known about the air filter, PCV valve issues for a while now. After going over the PCV system, replacing all the grommets, tubes, and clearing them of oi, my problem is that it STILL blows oil into the air filter. I know the line is clear of oil because I can feel suction in the line and the grommet going into the valve cover is brand new and free of oil.
I read somewhere that if it is still doing this after fixing the valve cover issues, then I have excessive blowby and my piston rings are shot. Is this true? Could I be missing something?
It seemed like a good idea at the time...
geusey is offline
post #2 of 4 Old 06-18-2013, 02:41 PM
idaholtby
Did you remove the valve cover, flip it over, remove the two "splash" towers attached to the inside of the cover and then clean the baffles out as well? I ask as you did not specifically state this, plus your rig does not have an actual PCV valve, it is a simple restricted orifice elbow, no valve. Looks identical to a PCV valve, but not. These baffles will clog over time and cause this issue.
idaholtby is offline
post #3 of 4 Old 06-18-2013, 02:49 PM Thread Starter
geusey
Yes I did. It's perfectly clear, thanks for asking. i forgot to include that I did that.
geusey is offline
post #4 of 4 Old 06-18-2013, 03:00 PM
idaholtby
Well, usually this will fix these type of issues. I would suggest that your next move would be to perform a compression test so that you know what you are dealing with.
