4.0 belt routing. AC vs non-AC - JeepForum.com
post #1 of 4 Old 08-08-2013, 04:51 PM Thread Starter
rykemc
Question.
95 4.0 with AC.
I still have the compressor mounted and the belt is running it although I do not have or plan to run the AC. Matter of fact my ARB twin compressor is sitting where the AC lines would be if I was.
My question is, if I remove the AC compressor do I just get a non-AC belt or is there more to it that needs to be done?
I'll hang up and listen.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #2 of 4 Old 08-08-2013, 05:01 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Non AC belt and I think there's a pulley that needs to be run. My jeep has the little sticker with belt routing information still on it, lemme pop outside in a bit and I will send you a picture of it.
Luck Favours The Prepared
Anticanman is offline
post #3 of 4 Old 08-08-2013, 05:13 PM
pasinbuy
If your remove the AC. Just go to a non AC belt and remove the top idler pully.
pasinbuy is offline
post #4 of 4 Old 08-08-2013, 05:13 PM
jeepster93
jeepster93's Avatar
You would bypass the compressor idler pulley too.
You should have 2 idler pulleys, one for the alternator and one for the air.
Here is a pic I used when I went the other direction, from no ac to a belt driven oba(air conditioner compressor).
You can see the set up is the same excluding the 2 things(comp, and idler in red).
jeepster93 is online now
