4.0 ax15 to dana 300 problems.Need help please - JeepForum.com
post #1 of 8 Old 02-18-2012, 11:09 PM Thread Starter
ymurf
1979 CJ7
I posted this in cj forum but being out of a 94 YJ I thought maby someone here could help me.I have been working on this swap into my 78 cj7 with a early YJ tub now for weeks in the evenings and weekends.Every time I think I am getting close I run into a problem. After finally getting the right clocking ring and ordering seals and getting them in I was going to put transfer case in awhile ago.First the tc shifter bracket is hitting floor cross brace which I can fix with a hammer or sawzall. Thats not whats bothering me.I am just now to where the threaded studs of the transfer case are touching the ax15 holes so I have probably an inch or so farther to slide up snug to the transmission and the TC shifter bracket is only about 1/4" from hitting the transmission on the side where there is a bolt.I see no way for it to go on? I know some of you have mounted a Dana 300 to an AX15.So please tell me what the heck is going on here before I give up.I have seen numerous threads about this swap that never mention this problem.Would appreciate any help here.Here is a pic I took through the tunnel showing where it is going to hit.I dont even have it clocked up level.It is clocked to factory 23 or so.
ymurf is offline
post #2 of 8 Old 02-19-2012, 07:59 AM Thread Starter
ymurf
1979 CJ7
Had a couple guys from the CJ forum said they had no trouble mounting theirs.What am I doing wrong?
ymurf is offline
post #3 of 8 Old 02-19-2012, 08:23 AM Thread Starter
ymurf
1979 CJ7
Does anyone here have a picture of a Dana 300 mounted to an AX15 so I can see whats going on?
ymurf is offline
post #4 of 8 Old 02-19-2012, 02:12 PM Thread Starter
ymurf
1979 CJ7
You can see in this pic where I have the studs mounted.If I go to the next set of holes it seems to me that would make it even worse.Seems it would hit even harder plus would really hit the tub.Any help would be greatly appreciated.Would love to get this mounted today before I give up on it.
ymurf is offline
post #5 of 8 Old 02-19-2012, 06:25 PM Thread Starter
ymurf
1979 CJ7
I cant see no other way,Going to cut the ear off and weld another ear on closer and shorten the rod to work and make some new brass bushings on the lathe.
ymurf is offline
post #6 of 8 Old 02-19-2012, 07:28 PM
Louie4
Sounds like you're going to make due with what you have. I know when swapping non stock parts into another vehicle you have to "make" things work and "finesse" some stuff.
I found this thread in the YJ forum but it's a flipped D300 with the AX-15. The shifter that you're having trouble with is on the bottom side.
http://www.jeepforum.com/forum/f12/a...37/index2.html
Our YJ's have a drivers side diff drop versus the CJ pass. side diff drop.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is online now
post #7 of 8 Old 02-20-2012, 04:19 PM Thread Starter
ymurf
1979 CJ7
I called Novak today.They said if you index transfer case to about factory angle like I have it you have to cut the ear off..If you clock it one set of holes up or more it will clear..Not sure if will clear tub when clocked..Thats my fault though,When I made my trans mount I put my motor level and made a mount that thick.The guy at Novak said The Jeep engine needs to be tilted back about 4. I didnt know that so now I have to cut my tranny mount out and start over. I always thought you wanted your engine level?
ymurf is offline
post #8 of 8 Old 02-20-2012, 07:34 PM
jsawduste
2006 YJ Wrangler
PM answered
jsawduste is offline
350 to ax15 problems Zeb89 YJ Wrangler Technical Forum 26 11-30-2011 02:34 PM
Ax15 Bleeding Problems Allen9878 YJ Wrangler Technical Forum 6 12-21-2010 12:32 PM
ax15 to dana 300 spacer antec YJ Wrangler Technical Forum 3 09-30-2009 02:55 PM
ax15 and Dana 300 or np231 antec YJ Wrangler Technical Forum 17 09-26-2009 11:47 AM
ax15 problems Redneck924 TJ Wrangler Technical Forum 6 02-25-2009 05:25 PM
