4.0 alternator upgrade - JeepForum.com
post #1 of 4 Old 04-18-2013, 10:00 AM Thread Starter
brockj
So I've done some searching and everything I read is about the 4.2 or 4cy. My questiong is about the 4.0 in my dad's 91. I've read about the 160a durango swap for 4.0 tj's and the 136a swap from a grand cherokee for tj's, but will these work on a 91 yj?
brockj is offline
post #2 of 4 Old 04-18-2013, 10:30 AM
Que89YJ
http://www.jeepforum.com/forum/f12/c...queel-1460052/
Go to post 14 for the list. You cannot use the CS-144. You must use the externally regulated. GC, Durango, etc. in the list.
Que89YJ is offline
post #3 of 4 Old 04-18-2013, 11:03 AM Thread Starter
brockj
The article only lists a 98 durango but can I still use the larger 160a from an 04-06, and I assume the wiring between the alternator and battery needs to be upgraded as well.
brockj is offline
post #4 of 4 Old 04-18-2013, 11:38 AM
Que89YJ
ve never seen anyone use the other years and I can answer about the 160 amp. Do a google and see if anyone has done it.
Que89YJ is offline
