3rd gen vortec engine with stock gauge - JeepForum.com
post #1 of 12 Old 01-18-2012, 09:36 PM Thread Starter
Ripper3494
ive got a question for you guys that have done genIII sbc swaps into your yjs. for those of you who retained stock gauges how did you do it with the oil pressure and temperature gauge? any diagrams would be nice.
thanks,
Erik
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #2 of 12 Old 01-18-2012, 10:14 PM
Plato2k5
just put the stock sending units in the sbc.
I myself would not want to run the stock gauges as mine were not accurate at all. I just put autometer gauges in behind the bezel, looks stock and you know its accurate.
:edit: sorry Im being ignant, computer controlled lol so my above advice would not work
Plato2k5 is offline
post #3 of 12 Old 01-18-2012, 10:16 PM Thread Starter
Ripper3494
lol thanks for the reply anyway. thats the kinda info ive been seeing, but the 3rd gen is a bit different than previous i believe
build thread:
RC vs BDS
post #4 of 12 Old 01-18-2012, 10:36 PM
Plato2k5
wait, no it should work like that..... because you could use (2) temp sensors, one for the computer, one for your gauge. I actually have my jeep set like that and its EFI...granted its megasquirt and lets you program it however you want. And for the oil pressure, your computer does not monitor that.
Plato2k5 is offline
post #5 of 12 Old 01-18-2012, 10:40 PM Thread Starter
Ripper3494
so i have the plug going into the sender on the oil pan, your saying that doesnt go to the pcm then?
build thread:
RC vs BDS
post #6 of 12 Old 01-18-2012, 10:43 PM
Plato2k5
hmm...let me ponder on this.... if I can't think of anything I'll ask my dad in the morning. He does the calibration on cars so knows what the computer sees
Plato2k5 is offline
post #7 of 12 Old 01-18-2012, 10:45 PM Thread Starter
Ripper3494
thatd be great, ill take a look tomorrow and see if i have any connectors that are left on the old jeeps harness that i can use
build thread:
RC vs BDS
post #8 of 12 Old 01-18-2012, 10:47 PM
Plato2k5
did a quick search and the PCM does monitor oil pressure.
as for the plug on the pan it would have to be oil temp
Plato2k5 is offline
post #9 of 12 Old 01-19-2012, 06:07 AM Thread Starter
Ripper3494
: aight so its apparent im not the best with the engine connectors lol
build thread:
RC vs BDS
post #10 of 12 Old 01-19-2012, 07:38 PM
kbktulsa
1987 YJ Wrangler
i am installing a LS 1 in my 87 wrangler. used the jeep oil sender on the bypass fitting by the filter, just drilled and taped it to 1/8 pipe thread and screwed it in there, used the stock jeep wire, on the pass side head, there is a plug toward the back, just taped it to 1/4 pipe thread and installed the stock jeep temp sender there, using stock jeep wirte. still used all LS1 senders for the computer.
kbktulsa is offline
post #11 of 12 Old 01-19-2012, 10:27 PM Thread Starter
Ripper3494
im afraid of screwing up the block while tapping something but ill take a look to see what i can do on it, it would be really nice to get my gauges working, since the jeep has been running ive been using an obdII reader on my phone
build thread:
RC vs BDS
post #12 of 12 Old 01-20-2012, 10:36 PM
kbktulsa
1987 YJ Wrangler
if you tap real slow and put lots of grease on the tap, turn a couple of turns and pull back out, wipe off filings put new grease and do it a little more, you get no filing in block, i have done this on several without any problems.
1987 jeep wrangler, 1999 LS1, 4l60E. 231j transfercase, D30 front, Ford 8.8 rear, 4 inch rc lift, tj top,tj fender flares
kbktulsa is offline
6.0L Vortec Engine.... mpentz1 TJ Wrangler Technical Forum 5 08-27-2011 04:06 PM
5.3L Vortec / 4L60E Engine swap mweber01 YJ Wrangler Technical Forum 9 08-10-2011 03:46 PM
2004 GM 5.3L Vortec Engine thekrutchmaster TJ Wrangler Technical Forum 21 03-06-2007 10:18 PM
Vortec Engine Swap xeon YJ Wrangler Technical Forum 3 03-22-2005 07:32 PM
TH400 in your jeep?Or vortec engine and tr Galvoknight YJ Wrangler Technical Forum 1 04-09-2002 07:49 AM
