3rd Gear Grinding?? - JeepForum.com
post #1 of 5 Old 04-21-2001, 10:44 PM Thread Starter
nole jeeper
3rd Gear Grinding??
I have a '94 YJ with a 5 spd. man. tranny. Just the other day it started grinding a little everytime I shift into 3rd gear (both up and down shifting) It only does this in 3rd and still gets into gear, it just grinds.
Any ideas?
nole jeeper is offline
post #2 of 5 Old 04-21-2001, 11:26 PM
Tonka
2015 JK Wrangler
check the fluid for the clutch. If it is low then pull off your slave cylinder and check for leaks. if you have any leaks replace the leaking parts. If that does not work then the problem is in the trans.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
post #3 of 5 Old 04-21-2001, 11:43 PM
osburn
osburn's Avatar
Sounds like a synchro!
Matt Osburn
Score 1032
osburn is offline
post #4 of 5 Old 04-22-2001, 02:35 PM
jeeptuff
I would have to agree with Osburn, I just in the last couple months went through the same thing. At the time I expected the slave, but in the 93's they have the hyd. throw-out which in turn is your slave too. You have to yank the tranny to do it, so I figured I would slap in the Centerforce Dual Friction too. Got all done and the tranny stabbed back in and guess what? Yep had to yard it all back out and tear into the tranny. What a *****, from a Sunday morning job to a full week. Bearing and syncro kit a gear cluster and 5th gear its self. Total cost about $900 bucks, I just hated pulling everything twice..
Eric
Once again Jeepless in Seattle
jeeptuff is offline
post #5 of 5 Old 04-22-2001, 03:35 PM
Cody_91YJ
I'd agree, if it was the clutch or throw-out bearings...it'd be grinding in Rev, and first. Plus be hard as hell to shift.
I just had all that replaced like JeepTuff here, but fortunately that solved the problem
'91 YJ Mangler w/ too many mods...and yet not enough ;)
Cody_91YJ is offline
RP Syncromax, 3rd Gear Grinding In Gear 242TJ TJ Wrangler Technical Forum 8 10-25-2009 01:06 PM
Grinding second gear!!! acat YJ Wrangler Technical Forum 3 04-17-2007 05:14 PM
2nd Gear Grinding?? nico1 TJ Wrangler Technical Forum 7 11-01-2006 10:04 AM
gear grinding iking87 YJ Wrangler Technical Forum 8 10-05-2006 05:42 PM
Help! Grinding 2nd Gear supertj4415 TJ Wrangler Technical Forum 7 03-23-2004 01:16 AM
