35x1250's on stock axles? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 35x1250's on stock axles?
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 04-22-2013, 02:59 PM   #1
trailnYJ
I have a 95 with a 30 in the front and 35, I've heard here and there that if I was to go any higher than 33's I could snap a shaft? And I have these 35's that I want to install. Advice?
95 YJ 2.5 4 banger with 4"rancho lift on top of 33x12.5/15
trailnYJ is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 03:26 PM   #2
Siva283
Ford 8.8 is my advice
[QUOTE=Magnum;14117863] I gave the Jeep the required offering of $$, sweat, and blood, and everything works fine now. -- Jim[/QUOTE]
[QUOTE=ldso;16498409]. It started with a $200 axle, and a few thousand dollars later I was done :)[/QUOTE]
[QUOTE=Luuca;16122017]diagnose the real issue before you start going all Obama on it - spending mad cash you'll need for other important things.
Ask me how I know...[/QUOTE]
[QUOTE=Overhead;17658665]this is also my second set of RC springs this year. I'd rather spend the money again and get something that will last.[/QUOTE]
Siva283 is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 04:58 PM   #3
Anticanman
RIP one good jeeper
Anticanman's Avatar
Breaking a shaft is an easy fix. Breaking a carrier isn't.
Luck Favours The Prepared
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 07:09 PM   #4
YJ4LIFE
i broke my shaft on 30's
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline   Reply With Quote Quick reply to this message
Unread 04-22-2013, 07:31 PM   #5
Anticanman
RIP one good jeeper
Anticanman's Avatar
Originally Posted by trailnYJ View Post
I have a 95 with a 30 in the front and 35, 2.5 4 banger with 4"rancho lift on top of 33x12.5/15
Please transfer this to your profile. You'll only ever have to type it one more time.
Unread 04-23-2013, 03:35 AM   #6
Sparrows
Check out this THREAD and you decide.
I'm running 35's on my turdy 5 right now...but I'm scared haha.
Since you have the 2.5L gearing/power may be an issue.
Cheers
[URL="http://www.jeepforum.com/forum/f22/warbird-2-a-2242713/"][size=3][b]WARBIRD 2[/size][/b][/URL]
[URL="www.exiledoffroad.com"][size=2][b]EXILED OFFROAD[/size][/b][/URL]
[size=2][b]June '13 YJOTM[/size][/b]
Sparrows is offline   Reply With Quote Quick reply to this message
Unread 04-23-2013, 11:34 PM   #7
SnowdogMarc
I blew up the spiders in my D35 with 33's. I also lost 5th gear and spent a lot of time between 3rd and 4th on flat ground. Upgrade to the 8.8 and regear if your planning on DDing the 2.5 or upgrade to a V6 or 8 and keep the stock gearing.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 12:18 AM   #8
TrentYJ
Cheers
I,too, like to live dangerously.
But in all seriousness you can run them if your conservative on the trail but you'll start to notice they like to take out other parts than just the rear end. (particularly rough on the steering gear and rod ends.) Also, it'll be slow as a turd which doesn't bother me but may be an issue for some. All in all, most people avoid them on a stock drivetrain as they tend to be gremlins that seems to wear out/break everything faster. But can you run them? yes and you can join me and sparrows in the 35's on 35's club
"Arguing over the internet is like running in the Special Olympics...Even if you win, you're still retarded."
-François-Marie Arouet
TrentYJ is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 06:34 PM   #9
trailnYJ
On thank you all I'm jut trying to do some thinking on them just cause its getting around tht time to get some shoes. I'm fine with slow just cause its the 2.5 and I love it keeps me out of some trouble :thumb:
Well ill let you all know what happen thanks again for the addvice
Unread 04-24-2013, 06:44 PM   #10
Xpress
Gearing is now going to be a real serious issue, not to mention if it's a manual. Clutch is going to have a good amount of stress on it, especially since you are going to have to slip it a lot to get going without stalling. You will likely have to go with 5.71 gears which won't fit in the 35. Not sure about the 30.
All about that unibody life.
Xpress is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 10:03 PM   #11
95YJRusso
I'm about to run 30's on my jeep, I dont offroad because my jeep has 217K on a four banger, (also broke college student, and not too much public land in CT) its all original, is it an awful idea to run 30's?
95YJRusso is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 10:12 PM   #12
Xpress
30's will be fine. Factory tire size is ~28", I've ran 29's no problems, most run 31's without issue.
Unread 04-24-2013, 10:16 PM   #13
102joe
X 2 , although I do have a 8.8 waiting in the wings . I also am running a 4.0 w/ 4 cyl axels (4.10 gears ) . If you have open diffs it s a little easer to test fait . I have found 4 high to pretty much be useless too , by the way .
REAL JEEPS HAVE LEAF SPRINGS
NO REALY ,, IT IS HIP TO BE SQUAIR
102joe is offline   Reply With Quote Quick reply to this message
Unread 04-24-2013, 10:53 PM   #14
Dake
Dake's Avatar
I have been runnig 35s on a Dana 35 for over 10 years I dont wheel it that hard just some trails and mud. It keep blowing the spider gears with 33s. Long story short the spider gears where chiped whan I opened it to do the 4.56s could not find any so I put in a lockright, back in 2000. Ran it as a DD till 2005 locked front and back. Im usually pretty lucky and did not give much thought till I joined this site. I plan on getting an 8.8 soon.
Dake is offline   Reply With Quote Quick reply to this message
Unread 04-25-2013, 12:46 AM   #15
SnowdogMarc
I ran 31's for 2 years before I went to 33's and no issues with the 31's at all...blew the spiders in under 6 months with 33's
Get one with Posi and the disk brakes...one of the best upgrades I've done next to the 4.3L and Ax-15
l_______
/l ,[_____],
l---L -[]lllllll[]-
