Quantcast 35's w/4:56 on a D35? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 35's w/4:56 on a D35?
Official Chassis Saver Rust Preventive Truck & Auto UnTJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 10-14-2009, 02:15 PM   #1
Puinsai
1987 YJ Wrangler
Hey guys, I got a deal on some 35x12.5x15's and i was thinking about throwing them on my rig. Right now I have a D35 geared at 4:56. I'm also in the middle of doing my 4.0l head swap on my 4.2l block. I kinda already know the awnser to this question, but i have to ask anyway. Will the D35 hold up as a DD with limited off roading until I can beef up the rear end, or will it snap the second I throw down on the throttle? Also, I'm in Alaska so I have limited access to junk yards and parts stores for a 8.8 swap. So I need to know exactly what to look for when looking for a 8.8 rear axle. Is there a link that shows what 8.8 are a direct bolt up job and what vehicles they can be found on? Preferably ones that are already geared to 4:56. Thanks much guys.
87 YJ []IIIII[]
3.5in BDS, 1" daystar MM, Posi Lock, D-30 w/Tru-track, Stock D-35, 33x12.5x15's, 4:56, 4.0l head swap, AX15 Swap, HEI, Howell TBI. AA SYE, Tom Woods DS.
Puinsai is offline   Reply With Quote
Old 10-14-2009, 03:22 PM   #2
93YJfalcon
Answer 1 - IMO ...
I'd wait to put em on.
Answer 2 - 8.8's are not a direct bolt in check the YJ forum FAQ for more.
answer 3 - I don't think they came with 4.56 gears. (I could be wrong but, I think 4.10's are the lowest)
ROCK OVER LONDON... ROCK ON CHICAGO!
http://dirtyfabworks.com/gallery.htm
93YJfalcon is offline   Reply With Quote
Old 10-14-2009, 03:26 PM   #3
flame0086
I don't think 8.8s come in 4.56 stock. I think 4.10 is the largest. I also don't think any of the are bolt on as the perches are not in the right location. If there is a bolt on, I would like to know.
Generally, you want an 8.8 out of a 95+ Ford Explorer. The Ford Explorer's have larger spline counts than a Crown Vic. or Ranger. 95+ because they came with disk breaks in those years.
Good Luck
100 mpg!! Western Washington Univeristy X-Prize Team http://wwuxprize.blogspot.com/
Support Search and Rescue
Get Lost
flame0086 is offline   Reply With Quote
Old 10-14-2009, 03:29 PM   #4
flame0086
Originally Posted by 93YJfalcon View Post
Answer 1 - IMO ...
My D35 blew up on the pavement under normal driving conditions when I was on 32s and alloy wheels. Now I'm on 33s and steel, and for some reason still running a D35
Get Lost
Old 10-14-2009, 03:57 PM   #5
Jesse_87
Good Luck
I would like to know if anyone has found a direct bolt on 8.8 also.
Jesse_87 is offline   Reply With Quote
Old 10-14-2009, 04:10 PM   #6
JFranko
JFranko's Avatar
It's all luck of the draw.
OP, I would advise not putting the 35's on, some people have wheeled their Jeeps with that setup fine, but a lot have also broke axles under normal driving conditions.
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff
RED JEEP CLUB MEMBER #494
JFranko is offline   Reply With Quote
Old 10-14-2009, 04:22 PM   #7
Puinsai
1987 YJ Wrangler
Being in Fairbanks Alaska, the last thing I want is to be stranded on the side of the road in -40 degree temp with a busted rear end. But man I would love to be rolling around in the snow on 35's. DAMN that D35!!!....DAMN it to HELL!!!!!!!
I just spent $600 last summer on re-gearing my d35.....I guess that was my first mistake.
I could brobably find a 95 ford explorer easy enough for the axle, but then I would have to spend a butt-load to get it geared and installed. Good thing my 33's look really cool because they might be on there for a while.
87 YJ []IIIII[]
Old 10-14-2009, 05:28 PM   #8
feuer895
I'm running 35" mtr's on my D35 with 4.56 gearing hasn't skipped a beat, i also DD it to school and back which is about 30mi one way.
J.E.E.P.
Just Expect Every Problem
feuer895 is offline   Reply With Quote
Old 10-14-2009, 05:57 PM   #9
KMA Krawler
If you don't plant your foot to the floor the D35 should be fine with 35's, I drove mine that way for 3 years
Co-Founder/ Administrator
KMA Off-Road Jeep Club
www.kmaoffroad.org
"UNANSWERED THREADS"
KMA Krawler is offline   Reply With Quote
Old 10-14-2009, 06:03 PM   #10
oteps
1980 CJ5
I know a guy running a D35 welded with 35's on a trail rig that gets wheeled every other weekend. But my yj project will get an 8.8 before it goes out of the garage.
oteps is offline   Reply With Quote
Old 10-14-2009, 06:08 PM   #11
NOAKES91yj
i wouldn't worry about it i wheel the piss out of mine and have 33's with a locker and no problem yet, my buddy is running a D35 with 36'' Ground Hawgs with a locker as a DD and doesn't have a single problem out of it, don't fix it if it ain't broken. You need to get full use out of that axle and that $600 you put in it
Only in a Jeep
NOAKES91yj is offline   Reply With Quote
Old 10-14-2009, 06:11 PM   #12
KMA Krawler
x2, when it breaks...upgrade!!!
www.kmaoffroad.org
Old 10-14-2009, 08:42 PM   #13
DEERSLAYER94YJ
OP Good luck!! I would carry a couple spare axle shafts with ya at all times if your gonna run the 35's. My D35 blew up with 33's at 45 mph, not fun at all!!
Nightcrew Member #093
DEER--- It's whats for dinner!!
DEERSLAYER94YJ is offline   Reply With Quote
Old 10-14-2009, 10:03 PM   #14
navman
I wheeled my d35 with 35"s for a while and didn't have a problem till it finally went, but it should have considering what I was doing. Some people have had them break on the road. I would find an 8.8 and start working on it so its ready when you are.
95 yj Mustang 5.0, RockKrawler Xfactor 7 front w/ORI stx's, BDS rear, 39" BFG Krawlers, "309" frnt axle
my build http://www.jeepforum.com/forum/f12/my-5-0-coilover-build-931241/
navman is offline   Reply With Quote
Glock Forum
