35's stock gears - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 35's stock gears
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 05-20-2010, 09:47 PM   #1
linusb
35's stock gears
I want to do my lift and mount up my 35's. Stock gears are 3.07 with i6. Will regear soon but can I drive it like a 3 or 4 speed in the meantime or will it put a lot of wear on clutch/tranny?
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline   Reply With Quote Quick reply to this message
Unread 05-20-2010, 09:53 PM   #2
Burns95
I ran my 35's for about a month with stock gears. The big difference is I had 4.10's instead of 3.07's. Its going to be a strain but would work temporarily. I went with an 8.8 swap and 4.88's. I highly recommend that setup. You could easily get away with 4.56's since you have the 4.0l. I say go for it. It will be a dog until you regear though.
Burns95 is offline   Reply With Quote Quick reply to this message
Unread 05-20-2010, 09:57 PM   #3
Sleuthhound
It will be an old dog past it's prime...are you going to be keeping the D35 or upgrading the axle too?
Sleuthhound is offline   Reply With Quote Quick reply to this message
Unread 05-20-2010, 10:07 PM   #4
MJMPC
Aint gonna be easy on the clutch.
MIKE
http://www.dav.org/
MJM Powder Coating
Elizabethtown Ky.
http://www.cityprofile.com/
MJMPC is offline   Reply With Quote Quick reply to this message
Unread 05-21-2010, 07:26 AM   #5
sloan74
Yeah man that is going to be rough....just be carefull
sloan74 is offline   Reply With Quote Quick reply to this message
Unread 05-21-2010, 07:33 AM   #6
little_Jeep
I had 3:07 gears and the 4.0L at one time in history... add the 35's and you will have a real dog on your hands. Forget trying to wheel it, you will be doing good to drive it on pavement without killing your clutch. I went with the 8.8 and 4:56 gears.... wish I had gone 4:88.
little_Jeep is offline   Reply With Quote Quick reply to this message
Unread 05-21-2010, 08:48 AM   #7
jdarg
Save enough to regear the rear axle at the same time, then don't use 4wd until you save more and regear the front to match. 4.88 is what you want, for sure.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline   Reply With Quote Quick reply to this message
Unread 05-21-2010, 09:46 AM   #8
linusb
Dang...was afraId of that. My plan is to pick up an 8.8 with stock 4.10s and regear front to match...figure I can save the expense of regearing the rear.
In any case, it sounds like I need to take care of rear axle and gearing before I mount up the big 35s.
Unread 05-21-2010, 09:56 AM   #9
zoomin0074
I have 33's , 4.0l, 3.07 gears.. Its a pig !! I am currently collecting parts for my 4.10 swap
94 4.0L 3spd. auto
3.5" Black Mountain lift
33x12.5x15 General Grabber MT's 15x8 4" backspacing black mountain wheels.
Red Jeep club #435
zoomin0074 is offline   Reply With Quote Quick reply to this message
Unread 05-21-2010, 10:59 AM   #10
little_Jeep
You could slap the 8.8 with 4:10 under the Jeep and then just drive in 2wd until you have the coin to regear both axles.
4:10's with 35's isn't great, but its a World better than 3:07's.
