350 swap. the time is near - Page 9 - JeepForum.com
post #121 of 182 Old 11-06-2012, 08:45 PM
YJames90
YJames90's Avatar
Originally Posted by yjtyler View Post
No matter how much u guys say it the tbi isn't going back on it right now. All my stuff came from summit today so I'm gonna start putting the carb stuff on in about an hour. And about the only carb i have ever had problems with was one that sat for 12 years.
You have to do whats right for you! Thats what makes our Jeeps ours
My 2.5 to 4.3 swap thread
YJames90 is offline
post #122 of 182 Old 11-07-2012, 02:40 PM
87TPIYJ
1987 YJ Wrangler
I'm in Jax FL. It might be a stretch with shipping, but you never know.
YJ 350TPI NV4500 SOA 8.8 Flat skid
87TPIYJ is offline
post #123 of 182 Old 11-07-2012, 02:59 PM Thread Starter
yjtyler
well this is from last night but better late than never. the brown santa brought me some gifts(ups) also got the manifold installed and the distributor in. the clearance for the hei is alittle close but should be good. also i had to grind a little off the front of the man to clear the accesory bracket. and also the 4 inner bolt holes needed ground a bit. overall a nice looking manifold.
http://www.jeepforum.com/forum/f12/350-swap-time-near-1406658
yjtyler is offline
post #124 of 182 Old 11-07-2012, 03:09 PM Thread Starter
yjtyler
tpiyj here is the place. and i was on my phone earlier so it didnt show ur location. not that im on the computer i see ur location!
Mshar Powertrain Specialists
3525 N 6th St Ste 4, Harrisburg, PA 17110
(717) 231-3900
yjtyler is offline
post #125 of 182 Old 11-07-2012, 03:33 PM
87TPIYJ
1987 YJ Wrangler
Thanks dude!
87TPIYJ is offline
post #126 of 182 Old 11-07-2012, 08:12 PM Thread Starter
yjtyler
got some more done tonight. installed all the sensors in the manifold and got the fuel regulator installed. tomorrow i will be setting the carb on.
yjtyler is offline
post #127 of 182 Old 11-08-2012, 06:12 PM
USMCBuckWild
Running stock Jeep fuel pump up to the regulator? Must be due to the location of the regulator. That looks like a pretty clean install up and out of the way.
I have a high flow mechanical on thefront of my 350, with some very interesting fuel line routing.
USMCBuckWild is offline
post #128 of 182 Old 11-08-2012, 08:15 PM Thread Starter
yjtyler
yeah im running the stock pump up to the regulator. and i had to change the output to the side port for the carb. got the plug wires back on and rewired the fuel pump and distributor. also got some of the vac lines hooked up and modded the throttle cable bracket to work.
yjtyler is offline
post #129 of 182 Old 11-09-2012, 09:17 PM Thread Starter
yjtyler
well she runs again!!!! this time it actually idles.
yjtyler is offline
post #130 of 182 Old 11-09-2012, 09:19 PM
YJames90
YJames90's Avatar
YJames90 is offline
post #131 of 182 Old 11-11-2012, 07:10 PM Thread Starter
yjtyler
didnt get too much done this weekend, had other things to do. but what i did get done. i cut and installed the E-fan and shroud. set the fuel pressure, and filled her back with coolant. and just a pic to throw in. this is what happened at the last mudbog. the other side is a chromo and was fine. the stock didnt fair so well. this is a dana44 from the ranger.
yjtyler is offline
post #132 of 182 Old 11-13-2012, 07:22 PM Thread Starter
yjtyler
got the carb tuned tonight and set the timing to 6 degrees. the thing idles great!! i may have to change the thermostat tho. i will have to wait till i can run it for real to find out tho. and also have to call the company about the gauges. the tach reads about 400 rpm fast and it will not adjust off of that. and also the volt gauge reads 10v all the time even when the battery charger is charging it to 15v.
yjtyler is offline
post #133 of 182 Old 11-14-2012, 04:36 PM Thread Starter
yjtyler
Well found out some freakin fantastic news tonight, my rear main seal is leaking!! also the volt gauge is a lemon. the only actual good news is i got the tach reading right.
yjtyler is offline
post #134 of 182 Old 11-19-2012, 05:21 PM Thread Starter
yjtyler
worked on the heep alittle more tonight. got the trans back out of it and the rear main seal out. the old seal wasnt even touching the crank on the outer lip. i hope a new seal solves the problem. i dont want to drop the trans again!!
hoist on once again.jpg   trans back out.jpg   back of engine.jpg   rear main seal.jpg
yjtyler is offline
post #135 of 182 Old 11-19-2012, 06:38 PM
87TPIYJ
1987 YJ Wrangler
Dang that's a big gap! That's weird.
87TPIYJ is offline
ford 8.8 swap in my 90 yj first time swap helpp!! LIjeep631 YJ Wrangler Technical Forum 26 02-19-2014 06:11 AM
time to swap swarrick308 YJ Wrangler Technical Forum 11 01-25-2010 09:55 PM
its come time for the swap 4.2 to 4.0 jake89yj YJ Wrangler Technical Forum 5 12-07-2009 01:26 PM
It is Time to Swap Recoil TJ Wrangler Technical Forum 2 12-30-2007 07:12 PM
Time to swap the 35 for a 44. Ethan03 TJ Wrangler Technical Forum 1 06-12-2006 06:12 AM
