350 swap. the time is near - Page 8 - JeepForum.com
post #106 of 182 Old 11-04-2012, 03:00 PM
YJames90
YJames90's Avatar
Hope you dont plan on crawling up hills without that TBI. I can sit at idle with mine. Automatic and TBI, Its whats best for off roading
My 2.5 to 4.3 swap thread
YJames90 is offline
post #107 of 182 Old 11-04-2012, 03:00 PM Thread Starter
yjtyler
I just want my Jeep back on the road. I am not to familiar with tbi injection. We have this carb on our mud truck and it runs like a champ! I just wasn't up to messing with the fuel injection.
http://www.jeepforum.com/forum/f12/350-swap-time-near-1406658
yjtyler is offline
post #108 of 182 Old 11-04-2012, 03:06 PM Thread Starter
yjtyler
If i can't get what i want for the injection i may just put it on the shelf and if i ever turn it into a trail rig maybe try to mess with it again if the carb becomes problematic. But i don't see it being a pure trial rig for a long time
yjtyler is offline
post #109 of 182 Old 11-04-2012, 03:07 PM
YJames90
YJames90's Avatar
I bet the mud truck dosent climb steep hills? Are you using the Jeeps stock fuel pump? I am with the 4.3 and its dead on pertfect
YJames90 is offline
post #110 of 182 Old 11-04-2012, 03:20 PM Thread Starter
yjtyler
No ur right it doesn't very much but we have climbed with it and it didn't cut out. Maybe a custom tuned chip would have fixed it but maybe it wouldn't have then i would be out a couple hundred bucks for the custom tune and still not have it fixed. With the carb i know i can make it run right. also my Jeep is not a dd it is about a 90% cruiser 10% Wheeler so if the carb works for 5 years before i have to switch to fuel injection that is fine with me.
yjtyler is offline
post #111 of 182 Old 11-04-2012, 03:58 PM
YJames90
YJames90's Avatar
Dude! It only been less then 2 months!. And its not your DD? Whats the rush?.
That motor and computer do not want you to change it over to a carb set up
Its a fine tuned machine being ran by the computer. You just had some tweaking and diagnosis to figure out.
Do not sell the EFI !!
YJames90 is offline
post #112 of 182 Old 11-04-2012, 05:56 PM
badbigred
carb all the way
Im totally with u on the carb thing. I just droped a 360 in my yj and was planning on running a efi with it intell I saw all the wires, then a ran lol. I ended up using a 600 cfm carb and so far has worked great! Even on hill clims and so on. The way I see it if it starts giving me problems I may try using one of those truck avenger carbs. Iv been told lots of good things about those!
badbigred is offline
post #113 of 182 Old 11-04-2012, 06:00 PM
Nadel
Nadel is offline
post #114 of 182 Old 11-05-2012, 02:04 PM Thread Starter
yjtyler
welcome to JF guys nadel, it would be nice to post up some info with ur jeep and not just a random pic in my thread. also fill out ur profile. not to be rude but what was ur intent for this pic... got home today and was kinda disappointing that the ups man didnt come today, o well its monday. i am going down to the garage in a little to install the new freeze plug and put the accessory brackets back on.
yjtyler is offline
post #115 of 182 Old 11-06-2012, 01:56 PM
Why J?
Why J?'s Avatar
What if you have problems with the carb set up? Are you going to diag it or run away?
The ECU in the EFI system does all the correcting for you. If its not right it can in most cases tell you what that is. If not simple diag procedures should get you there.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #116 of 182 Old 11-06-2012, 02:22 PM Thread Starter
yjtyler
No matter how much u guys say it the tbi isn't going back on it right now. All my stuff came from summit today so I'm gonna start putting the carb stuff on in about an hour. And about the only carb i have ever had problems with was one that sat for 12 years.
yjtyler is offline
post #117 of 182 Old 11-06-2012, 02:57 PM
youngjeepr
What year is your 350? If the intake will fit mine I'll let you know how much I'll pay for it
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #118 of 182 Old 11-06-2012, 04:17 PM Thread Starter
yjtyler
The engine is a 89.
yjtyler is offline
post #119 of 182 Old 11-06-2012, 05:49 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Hey Tyler, you said you got both the D-shafts done for $200? I just need my rear done and the best I have found so far is $250. Whats the name of the place I would like to give them a call. Maybe them shipping it would still be cheaper than my quotes I have received.
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #120 of 182 Old 11-06-2012, 07:38 PM Thread Starter
yjtyler
I will get the name and # of the place for u tomorrow. It is in pa not sure where u are located
yjtyler is offline
ford 8.8 swap in my 90 yj first time swap helpp!! LIjeep631 YJ Wrangler Technical Forum 26 02-19-2014 05:11 AM
time to swap swarrick308 YJ Wrangler Technical Forum 11 01-25-2010 08:55 PM
its come time for the swap 4.2 to 4.0 jake89yj YJ Wrangler Technical Forum 5 12-07-2009 12:26 PM
It is Time to Swap Recoil TJ Wrangler Technical Forum 2 12-30-2007 06:12 PM
Time to swap the 35 for a 44. Ethan03 TJ Wrangler Technical Forum 1 06-12-2006 05:12 AM
