350 swap. the time is near - Page 7 - JeepForum.com
post #91 of 182 Old 10-26-2012, 03:27 AM Thread Starter
yjtyler
The tbi trucks don't have a return nipple on the water pump for the heater core, it was originally in the radiator. Since this rad doesn't have that and i didn't want to buy another water pump,i had to tie the return in somewhere
http://www.jeepforum.com/forum/f12/350-swap-time-near-1406658
yjtyler is offline
post #92 of 182 Old 10-26-2012, 09:12 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #93 of 182 Old 10-26-2012, 07:29 PM Thread Starter
yjtyler
well filled her with coolant tonight and ran it for a while. the thing is WAY overfueling!!! i took the tbi off and backed the regulator off the whole way and it is still overfueling. i may have to buy a regulator and put on the frame rail to get the pressure down. i dont think the factory reg in the tbi can get rid of the fuel fast enough. i had the headers almost glowing at an idle and it was throwing blue flames out alot.. my tach is reading about 1k high so i have to figure that mess out, i also rigged up a temporary shifter. it is a 1/2 extension which fit almost perfect over the tower. i also put a socket on for a "knob" but i flipped it upside down after the pic. im soposed to have my fan shroud on monday and will be rigging up my slave cyl hose tomorrow( hopefully)
yjtyler is offline
post #94 of 182 Old 10-29-2012, 07:31 PM Thread Starter
yjtyler
well didnt get much of anything done. found out the slave cyl is metric threads so have to do something else there. i did get my o2 sensor in so hopefully that fixes some of the running rich problem. also not sure if i have to buy another ecm or not. the ecm i have is for an automatic so it idles at around 1k. i will have to do some research first tho. for right now tho im just waiting out Sandy...
yjtyler is offline
post #95 of 182 Old 11-01-2012, 05:42 PM Thread Starter
yjtyler
well im really p!ssed off right now. i found out the freeze plug in the pass side front of the block is leaking, and also this tbi setup is about to go bye bye!!! i am really thinking about buying a carb and a hei( hope an hei will fit, i may have to dent the tub a bit.) .... i havent completely made my mind up yet but i am really considering it.
yjtyler is offline
post #96 of 182 Old 11-01-2012, 08:13 PM
USMCBuckWild
HEI fits the same as a regular distro. I bit the bullet and bought an MSD billet. No complaints from my heep. Feel free to send me your TBI setup!
USMCBuckWild is offline
post #97 of 182 Old 11-01-2012, 08:19 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
The center valve cover bolts are different on your heads. On the carbed manifolds and heads the 4 intake bolts go perpendicular to the ground not the heads like the outer 4 are. You can make it work, just FYI though.
March 2017 YJOTM
87TPIYJ is offline
post #98 of 182 Old 11-01-2012, 08:51 PM
USMCBuckWild
He is talking about the intake manifold bolts on the center bolt valve cover heads. Just to clarify....
post #99 of 182 Old 11-02-2012, 03:36 AM Thread Starter
yjtyler
I know about the 4 center bolts (thanks anyway) if i do go this route i will put a man off craigslist and modify it. I'm not spending almost $200 for the right manifold. And i no the hei goes in the same, i only have about an inch behind my small cap. I have an old hei at the house i would test fit first. And i would take all the tbi stuff and shove it in a cabinet in the garage.
yjtyler is offline
post #100 of 182 Old 11-03-2012, 12:21 PM Thread Starter
yjtyler
Well i just ordered all the stuff to switch it over to carb. Wish i would have went this route to begin with. Anyone interested in buying the tbi stuff??!
yjtyler is offline
post #101 of 182 Old 11-03-2012, 01:08 PM
USMCBuckWild
Yup, this guy might be interested for the right price. Hell, I probably would have straight traded my carb/intake for your TBI setup
post #102 of 182 Old 11-03-2012, 01:15 PM
youngjeepr
X2
What all comes with the "TBI SETup"? And how much are u looking to get?
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #103 of 182 Old 11-03-2012, 08:07 PM Thread Starter
yjtyler
ok guys the tbi setup includes everything. all the engine sensors(not the vss) i just rebuilt the tbi. includes:
distributor, tbi unit, all sensors, basically brand new wiring harness, ecm, coil. prob more things that im forgetting.
i will include the manifold but if i do this, i will need something for shipping since it weighs a little.
for the people interested pm me what price u are thinking. i have a price i would like tho.
yjtyler is offline
post #104 of 182 Old 11-04-2012, 12:39 PM Thread Starter
yjtyler
got all the tbi stuff off the engine. also tore the front bracetry off to install a new freeze plug. still waiting to hear u guys offers on the tbi stuff.
the wiring harness comes with the stuff just not in the pic. there is a pic of the harness on page 4. also includes the ring that goes ontop of the tbi
yjtyler is offline
post #105 of 182 Old 11-04-2012, 01:17 PM
Why J?
Why J?'s Avatar
Your pulling the TBI because of why? You just need to diagnose your issue and fix it. Maybe have the ECU flashed.
Why anyone moves from modern fuel injection to dark age technology in a carb is beyond me.
To me it sounds like an intake leak.
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
ford 8.8 swap in my 90 yj first time swap helpp!! LIjeep631 YJ Wrangler Technical Forum 26 02-19-2014 05:11 AM
time to swap swarrick308 YJ Wrangler Technical Forum 11 01-25-2010 08:55 PM
its come time for the swap 4.2 to 4.0 jake89yj YJ Wrangler Technical Forum 5 12-07-2009 12:26 PM
It is Time to Swap Recoil TJ Wrangler Technical Forum 2 12-30-2007 06:12 PM
Time to swap the 35 for a 44. Ethan03 TJ Wrangler Technical Forum 1 06-12-2006 05:12 AM
