350 swap. the time is near - Page 6 - JeepForum.com
post #76 of 182 Old 10-20-2012, 05:45 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
I thought about an H pipe. I was thinking a cross over in front of the gas tank. Just make sure you get it made where it can unbolt or come apart or you will never get it off. The true duals work just fine though.
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #77 of 182 Old 10-20-2012, 10:21 PM Thread Starter
yjtyler
today i got the power steering lines bent and installed. cost me a whole $20 also, where the front grill center mount is, mine was half rusted through. so a welded a washer in so there was something there. got the grill and the rad mounted in. i have 5 1/2 inches between the rad and front of the water pump, i guess that is plenty. but anyway, it is coming together. i cleaned some more wires up and also removed the coolant overflow jug( the new rad has the fill on the opposite side) have to get another one to mount of the pass side. one things im still not sure of is for the slave cyl. i have to go to the parts store and see how a Chevy line looks and what ends they have.
http://www.jeepforum.com/forum/f12/350-swap-time-near-1406658
yjtyler is offline
post #78 of 182 Old 10-21-2012, 07:27 PM Thread Starter
yjtyler
got a little more done today. i relocated the factory expansion tank because im too cheap to buy a new one!! it isnt too bad of a fit. also got the autometer clock so i had to tear the dash back out to put it in. it works now!! installed the glove box for the 3rd time! and tied up some more wires. i need to find a good spot to mount this little guy too. i cant really go much farther with the dash until i make a trip to radio shack for some indicator lights. also today has been a month from when i started this swap!!!
yjtyler is offline
post #79 of 182 Old 10-22-2012, 02:56 PM
USMCBuckWild
Dakota Digital makes some really awesome stuff! Its not cheap though....
USMCBuckWild is offline
post #80 of 182 Old 10-22-2012, 03:55 PM Thread Starter
yjtyler
I know that little box was pretty salty!!! I'm wiring it in now.
yjtyler is offline
post #81 of 182 Old 10-22-2012, 04:15 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
So I think that I might have a solution to our master cylinder problem. I have read around that our master is not up to par for the slave. I'm still doing more research to find out exactly what bore size we will need. I'm thinking 1". Here is the compact design that will bolt up to the fire wall and still have room for the booster.
http://www.wilwood.com/MasterCylinde...ter%20Cylinder
March 2017 YJOTM
87TPIYJ is offline
post #82 of 182 Old 10-23-2012, 06:42 PM Thread Starter
yjtyler
well this post is for anyone thinking about doing a sbc swap. i was looking through just the receipts that i have( i dont have a lot of them) and my total so far is over $2500 doing a swap is not cheap!!!! so this should deter about 1/4 of the people asking how involved a swap is (people dont just have thousands of dollars laying around). also keep in mind i didnt have to buy a trans or t case as i had the truck i got them from. just thought i would put this up and show what a swap cost..
yjtyler is offline
post #83 of 182 Old 10-23-2012, 06:49 PM Thread Starter
yjtyler
also to 87 tpi i am going to try this first
http://www.jeepforum.com/forum/f12/h...-slave-839960/
i drilled and tapped the fitting tonight. if u do this, be careful. in the pic his is perfectly centered. on mine the nipple was not centered and when i drilled it to 5/16 to tap it, it almost was offset to one side to far and make one side VERY thin. i will take a pic of mine tomorrow and put up but is is pretty much the same as in the thread.
yjtyler is offline
post #84 of 182 Old 10-23-2012, 07:13 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
I would definitely want to see your pics. Problem is I don't have what ever that piece is he modded. If I can remember I will post pics of my slave and lines.
March 2017 YJOTM
87TPIYJ is offline
post #85 of 182 Old 10-24-2012, 01:43 PM Thread Starter
yjtyler
ok here is the fitting that i made
1. the fitting piece i cut off
2. the fitting
3. this is how close my fitting was to not working. it original nipple was not centered.
4. i wish it was one of these ( i got these at work, im a technician at Cummins)
yjtyler is offline
post #86 of 182 Old 10-25-2012, 04:10 PM Thread Starter
yjtyler
I got my dash installed but I'm not to happy with the drivers side dash. It is squished and the center cover is sticking out. I'm trying to figure out how to get the cover to stay back. 2 sided tape isn't strong enough. I will post pics tonite. Also got my rad house adapter
yjtyler is offline
post #87 of 182 Old 10-25-2012, 04:34 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
I remember having the same problem with mine. It's doesn't do it now. I believe I trimmed a little off the right side of it. Try loosening the screws on the center gauge pod. Then tighten down the driver side first. It will settle a little bit.
March 2017 YJOTM
87TPIYJ is offline
post #88 of 182 Old 10-25-2012, 07:17 PM Thread Starter
yjtyler
ok got some more done tonight. tomorrow i will be filling it with coolant so i can run it i bit longer. here are pics of the rad hoses and also the gap that i have in the dash.. the tangs on the back of this piece are gone, not sure what to do.
1,2 dash gap
3-5 rad hoses
6 dash lights( the autometer doesnt fit in very well)
dash gap.jpg   dash gap close.jpg   rad hose tee.jpg   rad hose t ins..jpg   upper hose.jpg
yjtyler is offline
post #89 of 182 Old 10-25-2012, 07:51 PM
USMCBuckWild
Those gauges look friggin AWESOME!!! Ok, please dissable your dash and send me the whole damned thing!!!
The piece with broken tabs is easy to find. I got one on eBay for $11 shipped
post #90 of 182 Old 10-25-2012, 10:30 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
What is the T in your lower radiator hose for?
March 2017 YJOTM
87TPIYJ is offline
ford 8.8 swap in my 90 yj first time swap helpp!! LIjeep631 YJ Wrangler Technical Forum 26 02-19-2014 05:11 AM
time to swap swarrick308 YJ Wrangler Technical Forum 11 01-25-2010 08:55 PM
its come time for the swap 4.2 to 4.0 jake89yj YJ Wrangler Technical Forum 5 12-07-2009 12:26 PM
It is Time to Swap Recoil TJ Wrangler Technical Forum 2 12-30-2007 06:12 PM
Time to swap the 35 for a 44. Ethan03 TJ Wrangler Technical Forum 1 06-12-2006 05:12 AM
