350 swap. the time is near - Page 5 - JeepForum.com
post #61 of 182 Old 10-13-2012, 04:35 PM Thread Starter
yjtyler
Yet another thing ugh!! My brand new autometer clock doesn't work. I have to call autometer on Monday to see what they have to say. That is just great cuz that means i have to tear the dash back out!
http://www.jeepforum.com/forum/f12/350-swap-time-near-1406658
yjtyler is offline
post #62 of 182 Old 10-16-2012, 08:21 PM Thread Starter
yjtyler
Well got the tbi rebuilt and installed, and it doesn't leak. Also relocated the coil so my new air cleaner will fit. But back to another problem... I went to crank the thing over and nothing. Also i don't have power to things( like gauges). I tied into wires that were ignition power(from wiring diagrams) but somewhere along the lines the wires are no longer connected to the ignition. So tomorrows job is to figure out how to get the power back.
yjtyler is offline
post #63 of 182 Old 10-17-2012, 07:32 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Subscribed. My 700r4 tranny died and I'm converting the keep back to 5 speed. Found a donor nv3500 w/ tcase out of a 98 Chevy 1500. Just curious to see how you do things with the drive train.
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #64 of 182 Old 10-18-2012, 04:28 AM Thread Starter
yjtyler
Only thing is u are going to have a 241t case and the sye for them are not cheap!! An update, got things to make power steering lines, also got my ignition wiring fixed( no ground to relay). So i tried to start it but have no spark or fuel.. Have to check some things tonight. Also i may have to shim the starter, it is a little noisy.
yjtyler is offline
post #65 of 182 Old 10-18-2012, 05:00 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Do you have the command track system still? If so can you re use the jeep vacuum switch? Also I have been tying to see if I can use a mechanical speedo (don't want to replace auto meter speedo)
March 2017 YJOTM
87TPIYJ is offline
post #66 of 182 Old 10-18-2012, 05:54 AM Thread Starter
yjtyler
If u are referring to the front axle disco, no i have a cable lock. And i think u can get a mechanical but in a standard length sye. Ur rear shaft well be really short tho
yjtyler is offline
post #67 of 182 Old 10-18-2012, 05:54 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
So I will be able to use the stock jeep clutch master cylinder correct? I think that's my last big concern
March 2017 YJOTM
87TPIYJ is offline
post #68 of 182 Old 10-18-2012, 08:00 PM Thread Starter
yjtyler
i am not sure i havent got mine hooked up. but the throw out fork is on the pass side not like the jeep. im not sure if i can get another hose to run to the pass side or not. i may have to buy a chevy master cyl. i already have a chevy slave cyl but idk of the line's fittings will match up... on another note IT RUNS!!!!! lol the issue was the electric spark control module was not fassened down and it is grounded through the screws. i had to adjust the distributor because it was wayoff! but she fires up and sounds mean with the block huggers!
yjtyler is offline
post #69 of 182 Old 10-19-2012, 04:36 PM Thread Starter
yjtyler
Filled the t case with fluid and started cleaning up some wires.. It is a huge relief knowing it runs!!!
yjtyler is offline
post #70 of 182 Old 10-19-2012, 08:24 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Would you mind taking a picture of your shifter location inside the cab? I'm trying to get an idea of where it's going to come out. If you could take a measurement from the fire wall to the shifter (inside cab) that would be awesome. Thanks dude!
March 2017 YJOTM
87TPIYJ is offline
post #71 of 182 Old 10-19-2012, 09:31 PM Thread Starter
yjtyler
There are a few pictures back farther in the thread that show the location. I will get a measurement for u tomorrow
yjtyler is offline
post #72 of 182 Old 10-20-2012, 12:23 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
My bad, I forgot I saw those pics when I first read your thread. Thanks for the help. Just want you to know I'm not trying to hijack your thread I just happen to be doing a lot of the same things you are so I am being curious george. Also my computer is dead so I'm following everything through my phone. If you have any questions about the swap (engine and wiring) send them my way. Again thanks for the help. CHEERS!
March 2017 YJOTM
87TPIYJ is offline
post #73 of 182 Old 10-20-2012, 12:30 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
I saw u wanted a pic of dual exhaust. Here is mine. I got the shorty headman headers. I think the 700r and np207 shouldn't be far off from the nv3500/np241 as far as clearances for your exhaust routing.
March 2017 YJOTM
87TPIYJ is offline
post #74 of 182 Old 10-20-2012, 11:57 AM Thread Starter
yjtyler
i measured from the front of the tunnel cover to the shifter and it is 7 inches. in my opinion it is perfectly placed because it is right in the middle, and it is about even between the dash and console for the shifter throw( which is very short). a question for the guys running duals, do u have a crossover anywhere for the 2 pipes to intersect. i always thought it was better to have an "x pipe" tied in somewhere?
yjtyler is offline
post #75 of 182 Old 10-20-2012, 05:46 PM
USMCBuckWild
No 'H' or 'X' pipe here. It helps even the exhaust pulse pressure, but you aren't building a drag car or circle track car. You should be just fine with the duals. If you really want to, run a home made pipe across the 2. Just make sure you can get it apart to get the exhaust out to drop the trans/case as needed
USMCBuckWild is offline
ford 8.8 swap in my 90 yj first time swap helpp!! LIjeep631 YJ Wrangler Technical Forum 26 02-19-2014 06:11 AM
time to swap swarrick308 YJ Wrangler Technical Forum 11 01-25-2010 09:55 PM
its come time for the swap 4.2 to 4.0 jake89yj YJ Wrangler Technical Forum 5 12-07-2009 01:26 PM
It is Time to Swap Recoil TJ Wrangler Technical Forum 2 12-30-2007 07:12 PM
Time to swap the 35 for a 44. Ethan03 TJ Wrangler Technical Forum 1 06-12-2006 06:12 AM
