350 swap. the time is near - Page 4 - JeepForum.com
post #46 of 182 Old 10-09-2012, 07:08 PM Thread Starter
yjtyler
im not even sure what it cost to have the d shafts cut/lengthened, i sent them out thru my work and havent got a bill yet. for the front shaft i used the chevy rear half and the shop slid the front jeep section onto the chevy section. i did this for a couple reasons. 1 i didnt want to have to change the yoke for bigger u joint on the dana 30 because in the future a 44 is going in. 2 the chevy shaft is about 1 1/2 times bigger around than the jeep one. 3 the rear of the shaft is a 1330 joint and didnt want to buy a new u joint or flange to bolt to t case.
yjtyler is offline
post #47 of 182 Old 10-09-2012, 07:20 PM Thread Starter
yjtyler
also just remembered from a pic at the top of the page... WARNING if u have a front axle disconnect like mine, if ur working under the dash remember it is there. it does not feel good smashing into ur eye!! i bruised the corner of my eye and swore like a sailor the other night. just some humor for u guys
yjtyler is offline
post #48 of 182 Old 10-09-2012, 07:29 PM
Tylerzap
Awesome
My 98 XJ "Zap" Build Thread
1988 Jeep Comanche 4x4 Longbed - POS
Tylerzap is offline
post #49 of 182 Old 10-10-2012, 01:59 AM
rcn11thacr
Exhaust routing fyi:
My 89 yj has block huggers with true dual exhaust and it works well. Should do the same for yours. I like the way the guages turn so u can see them better, the dash pods look nice.
rcn11thacr is offline
post #50 of 182 Old 10-10-2012, 06:43 AM
USMCBuckWild
My 91 has Hedman Hedders with 2 1/2" collectors, 2 1/2" pipe series 44 flowmasters and exit just in front of the rear shackles. True dual the whole way and tucked up nicelay inside the frame. Should be pretty easy for you, doesn't interfere with anything.
USMCBuckWild is offline
post #51 of 182 Old 10-10-2012, 07:18 AM
snail81
Hey can you post some pics? thanks
snail81 is offline
post #52 of 182 Old 10-10-2012, 03:29 PM Thread Starter
yjtyler
The more i looked at it tonight i am thinking duals will be easier. Yes can u post some pics of how ur exhaust is run so i can get some ideas.
http://www.jeepforum.com/forum/f12/350-swap-time-near-1406658
yjtyler is offline
post #53 of 182 Old 10-10-2012, 05:41 PM
USMCBuckWild
I sent pics. Feel free to post the pics of the abortion in my driveway commonly refered to as my Jeep.
post #54 of 182 Old 10-10-2012, 06:36 PM Thread Starter
yjtyler
ok i got my oil filter put on finally(i know big job) i finished up the fuel lines and got all the vacuum lines routed. i got this nice heat covering for the fuel lines, it should keep them protected. im getting closer one step at a time tomorrow night i am going to start putting the wiring harness on.
yjtyler is offline
post #55 of 182 Old 10-10-2012, 06:48 PM
YJames90
YJames90's Avatar
As I found out you have to heat shield the exhaust to not over heat the tranmission. I run duels and they are awesome
My 2.5 to 4.3 swap thread
YJames90 is offline
post #56 of 182 Old 10-11-2012, 06:25 PM Thread Starter
yjtyler
ok got the wiring harness in and hooked up to the engine. im having troubles with were to mount the ecm tho. i cannot find a good spot!! where are u guys ecm mounted??
yjtyler is offline
post #57 of 182 Old 10-12-2012, 08:09 PM Thread Starter
yjtyler
ok got some more done tonight. i tore the pita glove box out yet again!! and put the ecm in there. its a nice hiding spot for it. also got the plug wires on with the heat boots. i hope the headers dont melt the wires. also cleaned up some wires that were attached to the battery with a power bus.
yjtyler is offline
post #58 of 182 Old 10-13-2012, 10:32 AM Thread Starter
yjtyler
well im not a very happy camper at the moment.. i hooked up some more wires this morning that are necessary to run the engine. my plan was to start it for a few sec. just to here her run!!! i hooked the battery up and didnt small any burning wires so i was happy about that, turned my radio on and it worked, turned the lights on and they worked. i thought things were going good so i turned the key to the run position and instantly smelt gas! i looked out at the throttle body and it was soaked. so i blew it off with the air gun and this time watched when i turned the key. to my surprise gas was literally flowing out of the entire throttle body!! : i was fuming. so i tore the tbi unit apart on the bench. ( side note when i bought the engine the guy said he just rebuilt the tb, what a lieing POS!!!) this is what the gasket looked like when i tore it apart, the black is the gasket... guess my next step is to rebuild the tb.
yjtyler is offline
post #59 of 182 Old 10-13-2012, 10:50 AM
snail81
I know exactly what you mean. When I bought my 5.3 the pos told me "it ran good" liar
snail81 is offline
post #60 of 182 Old 10-13-2012, 10:56 AM
USMCBuckWild
I never trust what other people say unless they can prove it. Sorry to hear about your misfortune, but at least its. Pretty cheap fix, not an entire engine or a bad trans.
ford 8.8 swap in my 90 yj first time swap helpp!! LIjeep631 YJ Wrangler Technical Forum 26 02-19-2014 05:11 AM
time to swap swarrick308 YJ Wrangler Technical Forum 11 01-25-2010 08:55 PM
its come time for the swap 4.2 to 4.0 jake89yj YJ Wrangler Technical Forum 5 12-07-2009 12:26 PM
It is Time to Swap Recoil TJ Wrangler Technical Forum 2 12-30-2007 06:12 PM
Time to swap the 35 for a 44. Ethan03 TJ Wrangler Technical Forum 1 06-12-2006 05:12 AM
