350 swap. the time is near - Page 3 - JeepForum.com
post #31 of 182 Old 10-04-2012, 07:26 PM Thread Starter
yjtyler
ok got the dash installed tonight and tied a few wires up. also installed a relay under the hood for the coil supply. and i have to give summit some credit for my new oil filter adapter. from the time i ordered to the time it was at my house was less than 24 hours!!! cant beat that.
yjtyler is offline
post #32 of 182 Old 10-05-2012, 06:54 PM Thread Starter
yjtyler
ok guys, got a few more wires ran tonight and found out that i need to figure fuel and power steering lines out. the factory jeep lines were frozen in the steering box so they twisted off, cant use them. also the chevy lines are bent wrong. so not sure what i am going to do there. and the tbi unit takes o-ringed fittings so i need to buy new factory chevy fuel lines. also got the shifter tower in and cut the tunnel cover so it would fit. i took the factory info center and cut the speedo and tach housings off so i can still use the factory housing. just have to get lights to fit in the housing for turn signals and high beams. just a few more little things done.
yjtyler is offline
post #33 of 182 Old 10-06-2012, 05:47 PM
youngjeepr
I got custom lines made for my power steering and it works great! I'm sure you can get fuel lines made as well
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #34 of 182 Old 10-06-2012, 05:59 PM Thread Starter
yjtyler
For the fuel lines i think i am going to get "an" fittings then run them into the factory hard lines. For power steering lines I'm gonna buy a factory Jeep return but am still not sure about the pressure side
http://www.jeepforum.com/forum/f12/350-swap-time-near-1406658
yjtyler is offline
post #35 of 182 Old 10-06-2012, 06:38 PM
insaneinline
I bought a custom set fuel lines with the an fittings from pure choice motor sports they are the only ones that I could find that had the an fittings to fit the jeep fuel rail ,but they have Chevy an fittings also so you can get the fittings you need up at the motor for Chevy and the jeep ones for the hard lines also they have nice stainless braided teflon fuel lines
insaneinline is offline
post #36 of 182 Old 10-06-2012, 06:49 PM
insaneinline
post #37 of 182 Old 10-07-2012, 12:18 PM Thread Starter
yjtyler
ok i looked at my options for fuel lines an dont feel like spending $50 for 4 fittings to go to an. so i am going to buy fuel line repair kits and just bend the line to where i want it. then run rubber line to the factory hard lines. the 2 lines are $20 and i have plenty of rubber line laying around the garage.
http://www.summitracing.com/parts/RNB-800-151/
http://www.summitracing.com/parts/RNB-800-153/
these are the 2 lines i will be using. im trying to think what else i need to order at this time from summit.
what are u guys thoughts on rad hoses. should i get the flex stainless ones or try to find rubber hoses that are right?
yjtyler is offline
post #38 of 182 Old 10-07-2012, 05:48 PM Thread Starter
yjtyler
ok got the fuel lines ordered from summit, will either have them tomorrow or tuesday. once the fuel lines are in i can put the wiring harness on. i am going to buy a factory jeep return line for the power steering, but still in the air about the pressure size. i went to a line shop and they said that i would have to buy a new jeep line so they could cut the one end off and braze the chevy end on. kinda sucks to pay for a new line then pay someone to cut it in half and weld a new end on.
yjtyler is offline
post #39 of 182 Old 10-07-2012, 06:47 PM
racenmotorsport
Try NAPA. Most of those places I've seen can do it without having to buy new to cut.
racenmotorsport is offline
post #40 of 182 Old 10-07-2012, 07:03 PM
USMCBuckWild
Try a John Deere or CAT dealership. Anyone who makes custom hydraulic lines. They should have fittings for the power steering in stock. I think I paid $38 for both lines to be made.
I LOVE that dash! How did you make the gauges fit like that?
USMCBuckWild is offline
post #41 of 182 Old 10-07-2012, 07:23 PM Thread Starter
yjtyler
it is the dash made by gauge works. quadratec sells it but i wouldnt buy it from them. i got both off ebay for WAY cheaper than what they sell it for. now that it is installed i noticed my volt gauge is a bit crooked but im not tearing the whole dash back apart to fix it. plus i think the angle of the gauge make it look more crooked than it actually is. i think i payed 55 or 60 dollars for both dash pieces when quadratec sells one for $53.
yjtyler is offline
post #42 of 182 Old 10-07-2012, 07:45 PM
YJames90
YJames90's Avatar
Almost sure i ran the 4.3 hard lines to the YJ stock rubber lines with hose clamps.
. For the power steering i massaged the lines into making the correct bends to fit the YJ pump
My 2.5 to 4.3 swap thread
YJames90 is offline
post #43 of 182 Old 10-08-2012, 03:33 AM Thread Starter
yjtyler
That is what i have lines from a 4.3 but mine came from a 1500 truck not a Jimmy. The line i have is bent the complete opposite way and has a twist in the rubber hose when installed. It is that bad i don't think i can bend it to where i need it
yjtyler is offline
post #44 of 182 Old 10-09-2012, 06:15 PM Thread Starter
yjtyler
ok got the fuel lines from the ups man today. got them bent and installed and did alot better job than i thought i would. i also got my drive shafts back from the shop and got them installed.
pic #1-2 fuel lines
pic #3 the drive shafts
pic #4 rear shaft
pic #5 where i had to clearance the skid i bit more
pic #6 where front shaft is, plenty of room for headers
fuel line.jpg   fuel line 2.jpg   dshaft on floor.jpg   rear dshaft angle.jpg   front dshaft cleared.jpg
yjtyler is offline
post #45 of 182 Old 10-09-2012, 06:45 PM
YJames90
YJames90's Avatar
Nice!!
#3 I had to do the same
YJames90 is offline
ford 8.8 swap in my 90 yj first time swap helpp!! LIjeep631 YJ Wrangler Technical Forum 26 02-19-2014 05:11 AM
time to swap swarrick308 YJ Wrangler Technical Forum 11 01-25-2010 08:55 PM
its come time for the swap 4.2 to 4.0 jake89yj YJ Wrangler Technical Forum 5 12-07-2009 12:26 PM
It is Time to Swap Recoil TJ Wrangler Technical Forum 2 12-30-2007 06:12 PM
Time to swap the 35 for a 44. Ethan03 TJ Wrangler Technical Forum 1 06-12-2006 05:12 AM
