350 swap. the time is near - Page 2 - JeepForum.com
post #16 of 182 Old 09-24-2012, 02:59 PM
seattle_yj
subscribed. Looks sweet!
seattle_yj is offline
post #17 of 182 Old 09-24-2012, 03:25 PM
youngjeepr
where is the collector on your headers? Im running block huggers that come out int the center of the block and when I go wheelin my axle comes up and crushes my exhuast. I will be switching to shorty style headers.
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #18 of 182 Old 09-24-2012, 06:30 PM Thread Starter
yjtyler
I am i little concerned about this to, i am going to try to run the drivers side either under or around the front of the oil pan. I'm hoping i can get a tight enough bend off the collector so the d shaft won't hit it.
http://www.jeepforum.com/forum/f12/350-swap-time-near-1406658
yjtyler is offline
post #19 of 182 Old 09-24-2012, 07:17 PM Thread Starter
yjtyler
here are the headers installed. i will get a pic of where the drivers side collector is tomorrow. im not concerned about the down pipe hitting the axle, its the d shaft that i am worried about.
yjtyler is offline
post #20 of 182 Old 09-24-2012, 08:06 PM
youngjeepr
I have mine routed under the oil pan and it hits.. You don't want your exhaust to close to the oil pan or it will heat up the oil up.. So if you do route it that direction I would wrap it.
post #21 of 182 Old 09-25-2012, 01:49 PM Thread Starter
yjtyler
ok so here is where the collector is at. in the first pic u cant actually see the collector but u can basically tell where it is at. the second pic is from right under the output of the t case. from this view i think i am going to have enough room for the d shaft.
yjtyler is offline
post #22 of 182 Old 09-25-2012, 06:15 PM Thread Starter
yjtyler
didn't do anything to interesting tonight. just traced a few wires from a plug in the engine compartment from the factory harness into the old gauge plug. im using a few of these wires for my new gauges. installed the new sending units and got the coolant temp sensor wired in. also measured the driveshaft lengths and they are going to the shop tomorrow. the rear shaft is now 17" long instead of almost 19"(what it was before). o well. i also need to figure out what i am going to do for fuel lines. what have u guys done?
yjtyler is offline
post #23 of 182 Old 09-30-2012, 03:17 PM Thread Starter
yjtyler
Well didn't do much of anything this weekend. Had to much other stuff to do. So I'm headed to the garage now to make up for some lost time. Time to do some electrical!
yjtyler is offline
post #24 of 182 Old 09-30-2012, 04:02 PM
YJames90
YJames90's Avatar
Have you thought about about running true duel exhaust?. It was alot easier then cross overs and they are tucked up out of the way. Got to love the wireing, so much fun !
My 2.5 to 4.3 swap thread
YJames90 is offline
post #25 of 182 Old 09-30-2012, 07:16 PM Thread Starter
yjtyler
ok i have looked but i cant find it. does anyone have a pinout of the gauge cluster plugs.. i have some of the wires figured out but i need a few more and dont know which ones.
never mind guys i found it. will have to print it out and take it to the garage tomorrow.
yjtyler is offline
post #26 of 182 Old 09-30-2012, 10:17 PM
ltrail
1984 XJ Cherokee
I am going to run stock manifolds that dump out the end so I can clear DS and links on mine. Same concept, different beater.
Doing well though, well done!
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #27 of 182 Old 10-01-2012, 09:15 AM Thread Starter
yjtyler
I should have the drive shafts back the beginning of this week so i will see how close things are. And i snapped a stud off on my oil pressure sensor so i had to order another one. Pisses me of a brand new $22 sensor and the stud twisted off. O well i guess
yjtyler is offline
post #28 of 182 Old 10-01-2012, 07:25 PM Thread Starter
yjtyler
got some more wiring done. went through the factory plugs and got wires that i need. also got my dash mostly wired up. also reran my fuel pump wires and vss wiring.
yjtyler is offline
post #29 of 182 Old 10-01-2012, 07:29 PM Thread Starter
yjtyler
ok can someone please tell me what happened to all of my pictures!!
nvm
yjtyler is offline
post #30 of 182 Old 10-03-2012, 07:16 PM Thread Starter
yjtyler
ok got some more wiring done. i finished the wiring for the center dash and traced a couple odd wires that were hanging around. under the dash is a mess!!! but here is the whole dash and the wiring for the center.
also i have no idea what to do with the indicator lights( turn signals, high beam, etc.) can someone post up some ideas on what i can do?
yjtyler is offline
ford 8.8 swap in my 90 yj first time swap helpp!! LIjeep631 YJ Wrangler Technical Forum 26 02-19-2014 05:11 AM
time to swap swarrick308 YJ Wrangler Technical Forum 11 01-25-2010 08:55 PM
its come time for the swap 4.2 to 4.0 jake89yj YJ Wrangler Technical Forum 5 12-07-2009 12:26 PM
It is Time to Swap Recoil TJ Wrangler Technical Forum 2 12-30-2007 06:12 PM
Time to swap the 35 for a 44. Ethan03 TJ Wrangler Technical Forum 1 06-12-2006 05:12 AM
