350 swap. the time is near - Page 10 - JeepForum.com
post #136 of 182 Old 11-19-2012, 08:31 PM Thread Starter
yjtyler
yeah im not sure why this was like this. the seal did look like it was alittle crocked but not enough to make that big of a gap. i will put the new seal in tomorrow and see what it looks like.
http://www.jeepforum.com/forum/f12/350-swap-time-near-1406658
yjtyler is offline
post #137 of 182 Old 11-20-2012, 06:05 PM Thread Starter
yjtyler
well got the new seal in but now im fighting with the starter. i got a new started but it cant be right. i took a tooth off my new ring gear with is and it only engages half the way. i am getting a new one tomorrow along with a new ring gear. the $$$ just keeps racking up!!
yjtyler is offline
post #138 of 182 Old 11-20-2012, 08:31 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Did you shim your starter?
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #139 of 182 Old 11-20-2012, 08:45 PM Thread Starter
yjtyler
It isn't like that. I think the parts store gave me the wrong starter ( auto vs manual) the Bendix was only engaging half way into the ring gear teeth. The original 350 starter is right bit is to big. It is into the header. So i bought a 4.3 starter but somewhere something is different
yjtyler is offline
post #140 of 182 Old 11-21-2012, 08:33 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Its different between auto and manual? I compared my flexplate to the flywheel that I will be using and they were the same exact tooth count and size. Offset could be different though?
EDIT: Just re-read and saw that you used a 4.3 starter. What headers are you running where they hit? I used the Hedman shorty headers and I dont have any issues with starter or frame rail.
March 2017 YJOTM
87TPIYJ is offline
post #141 of 182 Old 11-21-2012, 04:46 PM Thread Starter
yjtyler
They will be the same tooth. Either 153 or 168. ( mines168) the starters, there is a difference between the twos nose lengths. And my starter was under the header flange.. I have a starter ordered that is shorter in overall length. Will have to wait and see how it fits once it comes in
yjtyler is offline
post #142 of 182 Old 11-29-2012, 08:11 PM Thread Starter
yjtyler
got a good bit done tonight. got new ring gear put on, installed the flywheel and clutch, installed the trans. put the skid plate back up with new bolts. i had a nice surprise when i went to put the rear dshaft back up. i accidentally bumped the one cap and it fell off and needles went everywhere!!! once i got that put back together and up i changed directions and started working on the rats nest of wires under the dash. i have a lot to do still but it is getting cleaned up.
yjtyler is offline
post #143 of 182 Old 12-01-2012, 01:48 PM Thread Starter
yjtyler
the jeep went on its maiden voyage today!!!!! the clutch is extremely tight. i went out the road and back. before i could not come up my driveway in anything other than 1st gear. i came up my driveway in 2nd at about 1k today this thing is a monster compared to the 4 banger!!
yjtyler is offline
post #144 of 182 Old 12-02-2012, 07:01 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
Congratulations dude! Take some pics!
March 2017 YJOTM
87TPIYJ is offline
post #145 of 182 Old 12-07-2012, 03:56 PM Thread Starter
yjtyler
the engine bay is almost done. i have to finish up some things tonight and get a hose for the crank case vent. i still need to get the t case shifter in and wire up reverse lights before it goes for exhaust. still not sure on what size to go with. 2 1/4 or 2 1/2 duals. also still looking at mufflers...
yjtyler is offline
post #146 of 182 Old 12-07-2012, 04:07 PM
ben34mod
Looks good! Congrats.
ben34mod is offline
post #147 of 182 Old 12-08-2012, 04:43 PM Thread Starter
yjtyler
got some work done today on the jeep. i got the t case shifter in and working... what a PITA that was!! it looks like poop right now but once the cover is on, u will never see it. and i got my front bumper back on. it looks mean again the last thing i did today was fix some more wiring. the PO really didnt believe in butt splice connectors. EVERYTHING is just twisted together and electrical taped so i went through and put splices in. it solved my one speaker pod acting up.
bumper back on.jpg   t shifter hole.jpg   tcase shifter.jpg   trammy hump cover 1.jpg
yjtyler is offline
post #148 of 182 Old 12-09-2012, 08:02 PM Thread Starter
yjtyler
the jeep is almost ready to go get exhaust! today i worked on getting the tranny hump cover in. welding sheet metal isnt easy! i got a sheet cut and welded in, i still need to get a shifter boot and put on but that can wait. the only thing left to do before exhaust is to put a 45 in at the slave cyl to get the line up out of the way. i want to keep the exhaust tucked up as tight as possible.( im thinking now i should have went with headers that exited at a 45 out the back) i had to put the top back on today, its a new record made it to December with the top off also for anyone who is interested here are some pics of the M.O.R.E. roll cage installed.
cover top.jpg   cover bottom.jpg   cover in 1.jpg   cover in 2.jpg   roll cage 2.jpg
yjtyler is offline
post #149 of 182 Old 12-11-2012, 02:51 PM Thread Starter
yjtyler
got some good news today. the jeep goes Saturday morning to get exhaust. hope i get it back before Christmas, it will be my present to myself
yjtyler is offline
post #150 of 182 Old 12-22-2012, 03:17 PM Thread Starter
yjtyler
i went and picked the jeep up last night from the exhaust shop. im very pleased with the work and for only $300!! i took it for a drive today, its first actual drive, the temp was fine just driving but when i got on it, the temp started climbing. i think i may need to drop to a 180 tstat. im not sure what others have but it almost feels like 4.10 gears are almost too deep now like im in 5th gear in no time. i really need to get my speedo working tho.
yjtyler is offline
ford 8.8 swap in my 90 yj first time swap helpp!! LIjeep631 YJ Wrangler Technical Forum 26 02-19-2014 06:11 AM
time to swap swarrick308 YJ Wrangler Technical Forum 11 01-25-2010 09:55 PM
its come time for the swap 4.2 to 4.0 jake89yj YJ Wrangler Technical Forum 5 12-07-2009 01:26 PM
It is Time to Swap Recoil TJ Wrangler Technical Forum 2 12-30-2007 07:12 PM
Time to swap the 35 for a 44. Ethan03 TJ Wrangler Technical Forum 1 06-12-2006 06:12 AM
