350 swap. the time is near - JeepForum.com
post #1 of 182 Old 08-17-2012, 05:49 PM Thread Starter
yjtyler
well everyone as the title says, i am getting close to swaping in the 355. i have almost all the major parts. the only thing im waiting on is i have to swap a dana 60 in a friends truck. the rear went out of it and it is in my bay. anyway the sye is a jb conversions super short sye on a np241 transfer case. the tranny is a nv3500 5 speed behind a 355 tbi sbc. i just got the flywheel resurfaced and put a new ring gear on it. also installed a new clutch. im glad i got the tranny and transfer case for free because stuff is EXPENSIVE!!!
yjtyler is offline
post #2 of 182 Old 08-17-2012, 08:07 PM Thread Starter
yjtyler
when i installed the sye i have a lot of play to the front output. i tore it back apart and traced it to the syncro. i dont care for the slop but im going to run it anyway. when others installed their sye, do u have this play too?
yjtyler is offline
post #3 of 182 Old 09-21-2012, 03:34 AM Thread Starter
yjtyler
Well the swap has officially started. Last night got the fluids drained pulled the rad and am getting ready to pull the grill. It is amazing how much room their is between the 4 angry squirrels and the grill/rad with the shroud and all out!!
http://www.jeepforum.com/forum/f12/350-swap-time-near-1406658
yjtyler is offline
post #4 of 182 Old 09-21-2012, 04:28 AM
SurferJ
Subscribed!
SurferJ is offline
post #5 of 182 Old 09-21-2012, 04:45 AM Thread Starter
yjtyler
I will post up some pics tonight. My computer crashed last night also, so i couldn't post any then
yjtyler is offline
post #6 of 182 Old 09-21-2012, 05:19 PM Thread Starter
yjtyler
well it has officially started, no turning back now! i do not plan on doing a how-to thread just some pics along the way.
this was from last night
1. my jeep looks soo naked without the stinger and warn!!
2-3. there is a ton of room in the engine bay with the 4 angry squirrels.
4. this is what i have got done so far tonight.. going back to the garage right after this post
i will post some more later. cuz im gonna be busy this weekend!
yjtyler is offline
post #7 of 182 Old 09-21-2012, 05:28 PM
ltrail
1984 XJ Cherokee
Its on! Happy to see this happening!
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #8 of 182 Old 09-21-2012, 08:48 PM Thread Starter
yjtyler
well didnt get that much more done tonight. pulled the entire exhaust, power steering res( both lines were frozen in the steering box so they are junk) dropped the trans case, and started to take loom off of wires. i only need a few wires but dont want to screw up and cut some wires i need. tomorrow i should be able to pull the engine and trans and start either ripping the dash apart or cutting the old mounts out. which ever i feel like doing first!
yjtyler is offline
post #9 of 182 Old 09-22-2012, 01:38 PM Thread Starter
yjtyler
There are so many wires!!! Got the engine pulled this morning, now trying to sort through some of the wires that i need to keep. I am deleting sensors first to try to narrow things down. Will post some more pics either tonight or tomorrow.
yjtyler is offline
post #10 of 182 Old 09-23-2012, 06:56 PM Thread Starter
yjtyler
ok everyone big update!! i will go in order.
1,2- the old engine is out!
3,4,5- this is all the body wiring, anything that was connected to the ecm cut cut and taken out!!
there are still a ton of wires in the harness for the factory gauges that i didnt want to cut out in fear of cutting wires that i will need.
engine out.jpg   4 cyl out.jpg   engine out wires.jpg   engine out wires 2.jpg   extra wires.jpg
yjtyler is offline
post #11 of 182 Old 09-23-2012, 07:04 PM Thread Starter
yjtyler
1- took a while to clean the frame up nice
2- this was the first time the monster was slid into its new home!
3,4- this is where the new mounts ended up being they are just tacked in these pics
5,6- the engine is finally sitting in there on its own!!!
frame cleaned.jpg   first fit.jpg   new mount.jpg   new mount 2.jpg   finally in.jpg
yjtyler is offline
post #12 of 182 Old 09-23-2012, 07:21 PM Thread Starter
yjtyler
i have to do some real work to the skid plate!! the t case hangs below the skid right now and the front output is below the front of the skid. we are going to put an inch block between the trans and skid to raise the trans up and if that isn't enough we will lower the skid 1/2 inch. also i have to take the oil cooler adapter off the top of the filter because right now the drive shaft would hit the filter. if all these mods to the skid don't work, i guess i will have to fab a custom skid up.
yjtyler is offline
post #13 of 182 Old 09-24-2012, 09:25 AM Thread Starter
yjtyler
Got the block hugger headers bolted up this morning. What a pita!!! Maybe i should have spend a little more and bought a good set.. O well,i will see how long it takes for these to burn out.
yjtyler is offline
post #14 of 182 Old 09-24-2012, 09:52 AM
cstone94
Subscribed, Good luck!
95' YJ - Warn Bumpers/Tire Carrier/Winch - 2.5L - 6" Skyjacker Suspension Lift - 4.10's - Locrite Locker - Dana 35/30 - 35" BFGoodrich KM2's
11' F250 - DD
1982 Toyota Pick-Up - Spray-On Yellow Rhino Lined - Chevrolet 305 H.O. - SM465 - NP208C - All-Pro Off Road 5" Springs - 35x15.50x15 Super Swampers
cstone94 is offline
post #15 of 182 Old 09-24-2012, 02:58 PM
ltrail
1984 XJ Cherokee
Get a remote mount filter adapter or 4wd filter adapter. The remote will allow you to place it wherever is best for you and the 4wd SBC one will turn the filter 90* so it screw on from the front. Both are cheap, last I bought the remote setup it was like $53 .
Clocking ring should help the saggy tcase
ltrail is offline
ford 8.8 swap in my 90 yj first time swap helpp!! LIjeep631 YJ Wrangler Technical Forum 26 02-19-2014 05:11 AM
time to swap swarrick308 YJ Wrangler Technical Forum 11 01-25-2010 08:55 PM
its come time for the swap 4.2 to 4.0 jake89yj YJ Wrangler Technical Forum 5 12-07-2009 12:26 PM
It is Time to Swap Recoil TJ Wrangler Technical Forum 2 12-30-2007 06:12 PM
Time to swap the 35 for a 44. Ethan03 TJ Wrangler Technical Forum 1 06-12-2006 05:12 AM
