350 swap questions - JeepForum.com
post #1 of 4 Old 07-30-2010, 12:15 AM Thread Starter
RedWind
350 swap questions
I am ready to do a 350 swap but just have a few questons
where can I find the motor mounts cause everyone i found was for a cj
can anyone tell me what transmission would have come out of a 1978 K20 5.7
or what transmission came out of a 1991 camaro 3.1 (I believe it is a 700r tranny but not positive)
and if either of them would bolt up to a 5.7 350 out of a 1970 monte carlo
also i know if the tranny from the 3.1 camaro is a 700r it would need a 231 tranfer case that drops on the driverside from a s10 or blazer but what transfercase would the one from the k20 need
also what solutions would there be converting with the fuel pump since it is in the tank and it is obviously going to carborated
also if you have any tips for me they would be aperciated
My Jeep Build -->
RedWind is offline
post #2 of 4 Old 07-30-2010, 07:21 AM
leadsled01
"Brown Dog" should have your motor mounts.
leadsled01 is offline
post #3 of 4 Old 07-30-2010, 07:42 AM
XJinCT
AA has the mounts
v6 camaros have diff bells than a v8
2wd and 4wd 700r4s have different spline counts
in rebuttle to your opening statement, you are not ready to do a 350 swap
03 cobra. mods: ya its got em. power: enough. 1/4 et: faster than i can drive it
92 yj. lt1/700r4/np231cj/soa/8.8...blah blah blah in the works
XJinCT is offline
post #4 of 4 Old 07-30-2010, 07:50 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Pretty sure brown dog only offers stock upgrades for motor mounts, and not conversion mounts. Advance adapters or Novak would probably work.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
body swap VS motor swap questions baltimorebiker YJ Wrangler Technical Forum 9 03-29-2010 09:49 PM
8.8 swap questions...i know... machinehead131 YJ Wrangler Technical Forum 18 08-14-2009 08:45 AM
2.5L to 4.0L swap questions ZJ1209 TJ Wrangler Technical Forum 13 04-23-2009 09:34 PM
2.5 to 4.0 swap questions dunedude YJ Wrangler Technical Forum 2 11-20-2006 05:15 AM
Swap Questions? vantan YJ Wrangler Technical Forum 0 06-18-2006 10:39 AM
