350 swap problems, help me out
#16 | |
as far as the clutch master cyl. The original master cyl and slave were designed to be changed as a set. Hence the way the line is made on there.... you will probably have to find a master cyl to match the slave you have and get the style hose that connects those 2.
I scrapped all my emissions I cant help you there, anything with vacuum went to my intake, except the PCV that is connected to my carb.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies TRAIL TESTED (currently under the knife) 1946 CJ2A, 225 V6. mild lift - TIME TESTED 1966 M416 1/4 ton Military Trailer -- WAR TESTED Full Page Club member #004 Green Jeep Club Member #005 |
#17 |
As for the master cylinder problem I think jeepfreak hit the nail on the head. The 90's master and slave cylinder were meant to be changed as a unit. The 88 cylinder I have is seperate I guess it was de to the puecrap transmission.
what I would due is go and get a clutch master cylinder off of a 88 wrangler find a hose that fits I think I used one off of a CJ. and shortened it a little bit. The slave cylinder I used was off of an 80's CJ with 4cylinder.
88 Wrangler 350 Chevy engine vortec heads Holley Pro-Jection Ford T-18 Tranny Dana 44s Detroits w/ 5.89s 38" Swamper SX Lots of other random things and dents |
#18 |
alright, through some research, and a friend, looks like just brake line will work, little easier to work with, and it will seal on the nipple, with some type of clamp. Wiring tomarrow
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project Interned at Novak Conversions 2 summers ago |
#19 |
alright, I think I may have the clutch figured out. here are my latest pics (the newer ones are towards the end of the album)
http://community.webshots.com/album/538175648sfnMxG
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
