350 or stroker or 4.2 - JeepForum.com
post #1 of 20 Old 02-01-2013, 03:42 PM Thread Starter
bigwhiteyj
Okay guys I am wanting to upgrade my engine a little and I have a 350 but It needs rebuilt! My jeep has a 4.2 so I don't know wether to just do the 350 swap or build a stroker or just rebuild my 4.2 I am wanting something that doesn't cost more than about 1000$ and it is a 1988 jeep yj with a 3 inch lift and 33 tires I would like to put a bigger lift and heavier axles too? Any ideas? I am in high school and have a shop but it is my daily driver for a while longer
bigwhiteyj is offline
post #2 of 20 Old 02-01-2013, 03:45 PM
lsukevinc
1979 CJ5
no way you can do a 350 swap for under $1000. Plus if the motor needs a rebuild even more money. The adapter alone could cost $500 to mate the 350 to your tranny.
lsukevinc is offline
post #3 of 20 Old 02-01-2013, 03:50 PM Thread Starter
bigwhiteyj
I have seen a adapter for 250$ but I was just reading that my automatic transmission wouldn't take it so 350 is out!
post #4 of 20 Old 02-01-2013, 04:10 PM
yjtyler
yes u can rule the 350 out. i have about $3000 to $3500 in my swap doing basically all labor myself and i already had a chevy trans and tcase. i think the best option would be a stroker but with ur budget a standard rebuild may be better.
http://www.jeepforum.com/forum/f12/350-swap-time-near-1406658
yjtyler is offline
post #5 of 20 Old 02-01-2013, 08:59 PM
kgb_m3
Interesting, I'll be in the same boat at the end of this year. Either go nuts on the 4.2 and keep it or go with motor swap, most likely 350.
What's all involved with stroked 4.2? Will it pass smog after still? How much in parts? How much gains?
89 YJ 4.2L
96 XJ 4.0L
http://www.jeepsunclassified.com
kgb_m3 is offline
post #6 of 20 Old 02-02-2013, 02:33 AM
Michaelgoesrawr
You can't really build a stroker out of a 4.2 because it is already kinda stroked. Strokers basically takes the crank, rods and pistons and stick them in a bored out 4.0. They will pass smog like any other motor and no one will know what it is unless they dyno it.
Michaelgoesrawr is offline
post #7 of 20 Old 02-04-2013, 07:00 PM
kgb_m3
Got ya, I gotta do some more research when time comes.
89 YJ 4.2L
96 XJ 4.0L
kgb_m3 is offline
post #8 of 20 Old 02-04-2013, 08:04 PM
Michaelgoesrawr
Sorry, it takes the internals I mentioned out of a 4.2.
post #9 of 20 Old 02-04-2013, 09:58 PM
kgb_m3
Sorry to thread jack, quick question. So if I was to take out the internals out of my 4.2 and install them into a 4.0 head on the 4.2 block. That would yeild more power? If so, approximately what numbers are we talking here?
89 YJ 4.2L
96 XJ 4.0L
kgb_m3 is offline
post #10 of 20 Old 02-04-2013, 10:40 PM
skyj
No you got it backwards. You use a 4.0 block ,4.2 crank and rods, with 4.0 piston with a 4.0 head. That's kind of the recipe for a poor man's stroker in a nutshell. If you use 4.0 rods you will need custm forged pistons. Thats the simple version.
build thread:
skyj is offline
post #11 of 20 Old 02-04-2013, 10:53 PM
Michaelgoesrawr
Ah my bad. I forgot the pistons were 4.0.
But you can put a 4.0 head on your 4.2. Probably get you 20-30 hp if I remember correctly. Not entirely sure though.
post #12 of 20 Old 02-05-2013, 07:05 AM
skyj
Yep I run a 4.0 head on my 4.2. You will definaltely notice the power difference. There are some modification to the head and also the intake you have to do to make it work. Here is a link to my build. I have a link in my thread to a very good write-up on a 4.0 head swap its what I used to do mine. Been running it for 3years now http://www.jeepforum.com/forum/f12/s...build-1467426/
build thread:
skyj is offline
post #13 of 20 Old 02-05-2013, 09:04 AM
MLJeeper
MLJeeper's Avatar
If you do the head swap, have your machinist shave the head enough to give you a .5 to 1 point bump on compression. Give you a decent boost in torque for little investment.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #14 of 20 Old 02-05-2013, 09:49 AM
Beachcruiser
1987 YJ Wrangler
For a Grand (with access to a shop) I would:
Do a leakdown test to see if your 4.2 has good ring seal.
If so, I'd install the following:
4.0 Head & exhaust header.
New performance intake manifold (offy, etc) and small 4 barrel carb.
Upgrade ignition/coil system.
probably out breaking stuff.
Beachcruiser is offline
post #15 of 20 Old 02-05-2013, 10:06 AM
Drix
If your gonna do the head wouldn't you be able to move the manifold and bring the efi from a 4.0 over also.
95' YJ 4" lift 33"x12.5r15's D30/8.8 locked with 4:88's
USMC Jeep Club #6
"Why in hell can't the Army do it if the Marines can. They are the same kind of men; why can't they be like Marines."
Gen. John J. "Black Jack" Pershing, USA; 12 February 1918
Drix is offline
