350 motor mounts - JeepForum.com
post #1 of 6 Old 10-06-2013, 02:43 PM Thread Starter
Mattias25
350 motor mounts
Should I use welding or bolt on for 350/nv3500. Haven't done welding in awhile
Mattias25 is offline
post #2 of 6 Old 10-06-2013, 03:29 PM
SeanB95YJ
weld-em... get yourself some scrap 3/16 and 1/4" steel and run a few practice beads... when you weld the mounts, knock off the slag and check the bead. you can always run a 2nd pass at higher power or slower speed if necessary.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 6 Old 10-06-2013, 06:17 PM
YJames90
YJames90's Avatar
I bolted mine to the frame with 2 bolts on each side. No problems so far
My 2.5 to 4.3 swap thread
YJames90 is offline
post #4 of 6 Old 10-06-2013, 07:37 PM Thread Starter
Mattias25
who makes those mounts
post #5 of 6 Old 10-07-2013, 03:54 AM
YJames90
YJames90's Avatar
http://www.spoilersforless.com/advan...-engine-mount/
YJames90 is offline
post #6 of 6 Old 10-07-2013, 04:14 PM
snail81
weld them
snail81 is offline
