350 guys or mechanics - Page 2 - JeepForum.com
post #16 of 20 Old 04-21-2013, 09:38 AM
youngjeepr
If your choke isn't hooked up I would bet that's your problem. Is the choke flap open or closed when your engine is up to temp(180*-210)? I would reroute your fuel lines so you don't snag them on a rock or something. Does it get to the point where your motor will die and not start till it cools off?
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #17 of 20 Old 04-21-2013, 10:04 AM
jsawduste
2006 YJ Wrangler
Phil, when you replace the module in the HEI be sure to use the heat barrier gel/paste. Die electric grease is not the proper product. There should have been a packet of party gel with the module.
jsawduste is offline
post #18 of 20 Old 04-21-2013, 10:07 AM
UZI4U
Hook up your choke or set it wide open so it isn't closed when cold.
MCLMM
UZI4U is offline
post #19 of 20 Old 04-21-2013, 11:06 AM Thread Starter
phil1330
1964 CJ5
changed control module,vac advance, and coil. advanced timing and moved choke dial back one line. with all that being done the thing runs like a champ. Even feels like i have more power and throttle response. I have not done anything with the fuel lines yet.
But there is a resulting issue now the idle is really high on crank..drop it into gear idle is norm.
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
post #20 of 20 Old 04-21-2013, 11:07 AM Thread Starter
phil1330
1964 CJ5
ALLLrightty then...I did not do this...I'm going back into the distributor. Thanks
phil1330 is offline
