350 ecu question - JeepForum.com
post #1 of 5 Old 10-06-2013, 07:48 PM Thread Starter
Mattias25
350 ecu question
87 350 tbi, if i wanna keep manual do i need to get a computer that had manual tranny inside of the auto tranny computer that came with the 350 i have
Mattias25 is offline
post #2 of 5 Old 10-07-2013, 07:42 AM
Que89YJ
What trans and year ecu setup are you using?
Que89YJ is offline
post #3 of 5 Old 10-07-2013, 10:09 AM Thread Starter
Mattias25
I was gonna just grab 87 out of the 2500 and pull me gm nv3500
post #4 of 5 Old 10-09-2013, 12:57 PM
Que89YJ
From an 87 it really shouldnt matter. Look at this web site:
https://www.novak-adapt.com/catalog/...s/adapters.htm
Que89YJ is offline
post #5 of 5 Old 10-09-2013, 02:15 PM
SeanB95YJ
with an 87 you should be fine... from what I remember, the ECU doesn't get any critical info from the trans (possibly none at all, I'm trying to forget)... there's a signal FROM the ECU for the auto to lock the TCC (if it's a 700r4). the only signal I recall the ECU getting from anywhere near the trans (but it's not the trans) is the VSS signal coming form the tail of the transfer case and the NSS from the shifter... the VSS signal will be the same whether auto or manual, and the NSS can just be bypassed.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
