350 conversion questions (hopefully answers) - JeepForum.com
post #1 of 2 Old 11-25-2008, 10:01 AM Thread Starter
demoguru
I just happened upon a cheap LT-1 350 (fuel injected, full roller) engine. I have a 91 with a 4 cyl now. I am thinking about making the big swap. I know they sell conversion kits. Who would you suggest that I get a kit from? I assume "IF" I decide to do the swap I will be in for a long process of conversions. (axles, trans, transfer case ect) I am just looking for some general advice from someone who has done this right now. Once I decide I will be more specific. I cost total would be cool if you still have any idea what it cost you.
I am a demo derby driver so I know how these...."OH, just slap it in and weld it thing works.....NEVER DOES!!! Always something that needs changed and made and changed and made.....
Thanks,
demoguru is offline
post #2 of 2 Old 11-25-2008, 10:07 AM
yjwrangler08
i put a carb'd 350 with th350 in my jeep last winter. i used novak t-case adapter and novak weld in motor mounts. ummm total cost i think was righ taround 3,000 with cost of all the parts. i still run bone stock axles and the stock t-case with 33" tires. id deff recomend doing the swap, but you will need to change the trans when you do it. the 4 cyl trans wont hold up to the power
yjwrangler08 is offline
Herculiner How To, with questions and answers!! Jeebs YJ Wrangler Technical Forum 222 11-29-2014 01:03 PM
Fuel Tanks Swap Questions. Need Answers rocknjeep YJ Wrangler Technical Forum 13 11-18-2008 05:04 PM
3 questions with easy answers !?! jeep2008 TJ Wrangler Technical Forum 19 10-07-2008 05:39 AM
Frequently Asked Questions (FAQ) Your Answers Are Usually Here! NaeKid YJ Wrangler Technical Forum 16 12-16-2007 11:10 PM
Three quick questions I couldnt find answers to redline73 JK Wrangler Technical Forum 12 12-07-2007 12:58 PM
