350/700r4 swap question? (21 spline) - JeepForum.com
post #1 of 6 Old 09-05-2011, 01:57 PM Thread Starter
WilliamMc
Okay Iv done a lot of reading and not come up convinced about the 21 vs 23 spine question. I am helping a friend replace his rapidly declining 2.5 ans AX5 with a mostly stock rebuilt 350 and 700r4. The tranny is a 2wd set up and we planed on buying the kit with the adapter and output shaft to put it in frount of the 231 tc. We are going to have the tranny rebuilt anyway as it is high miles. The jeep just has 31 inch tires and see's no real heavy offroading. Although the 23 spline input setup probably would be stronger, Has anyone actually had problems with a 21 spine V8 conversion?? Has anyone done this with the 21 spline and had so far good luck? Is it really that much of a worry?
WilliamMc is offline
post #2 of 6 Old 09-05-2011, 03:44 PM
hesserdude07
why dont you go to anyjunk yard and get a 4x4 700r4? even if its junk you can take the rear housing off it and make your 2wd into a 4wd tranny. And then use a NP231C front case and your NP231J rear housing. Nothing fancy to buy or spend a ton of money...
1993 Silver YJ. SBC 300hp. 700r4. NP231 hybrid. 35" Mud Terrains. 7" Toyota Basterd packs. 8.8 Welded. D30 loc-rite. 1" body lift. 4" LED tails. Custom bumpers. Warn M8000. Hella's. (Trail rig)
hesserdude07 is offline
post #3 of 6 Old 09-05-2011, 04:13 PM
jeepercreeper77
jeepercreeper77's Avatar
So if you have a 700r4 out of a 1/2ton 4x4 you can just use a np231c transfer case out of s10?The reason I ask is I will be doing the same swap soon.
90 wrangler,4.2l,1" MML,CRT HEI Dist.,34/34(interco) weber, hurst shftr,5spd,5" BDS lft,f-d30/r-8.8,5/8 lft booms,1" bl,tflex belly up,JB convs. SYE,gdyr mtr35s,hurc'ed,smit src frt bump,gen-r rear bump w/tire carrier,f&r tube fenders,psc knokrs,r gen-rgt ful conr gurds,duel bat.,BIC,m8000
jeepercreeper77 is offline
post #4 of 6 Old 09-05-2011, 04:36 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
I think the 21 spline shaft would be fine with a mild 350 and 31's.
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
post #5 of 6 Old 09-06-2011, 03:24 AM
hesserdude07
Makes no difference what the 700r4 comes out of, but yes you can use the 231c out of a s10. My front case is from a 89 S10 blazer, a run a wide chain kit (i dont remember where i bought it, off line somewhere), my rear 231j case, and a JB conversions SYE.
post #6 of 6 Old 09-06-2011, 02:54 PM Thread Starter
WilliamMc
We already have the 700r4 and we are going to rebuild it anyway so it just seems easest to just get the 21 spline shaft and adapter and thats it, we can bolt up. I just got thru talking to a local old time 4WD shop owner, (Lee), and he also said he would not worry about the 21 spline, he has done many V8, auto conversions with a 21 spline output shaft and he has never had one, (the shaft), break even though he has had a few come back with transfer case failure's and he comented he has people come back that have torn up every transfer case there is. He thinks we will be fine as long as we are aware of the limitations of a 231 in general.
700R4 swap question MakoML TJ Wrangler Technical Forum 13 12-28-2013 09:58 AM
700r4 swap??? dadstoys2 YJ Wrangler Technical Forum 27 09-16-2011 05:56 PM
Question on TV cable for 700R4 in carbureted SBC swap vanwyk4257 YJ Wrangler Technical Forum 0 10-14-2010 02:41 PM
350 w/700R4 swap ecm tranmission question Mississippi 92 YJ Wrangler Technical Forum 5 07-09-2009 12:11 PM
700R4 Tranny swap wml52 TJ Wrangler Technical Forum 4 10-11-2005 02:45 PM
