35's stock gears - JeepForum.com
post #1 of 10 Old 05-20-2010, 08:47 PM Thread Starter
linusb
35's stock gears
I want to do my lift and mount up my 35's. Stock gears are 3.07 with i6. Will regear soon but can I drive it like a 3 or 4 speed in the meantime or will it put a lot of wear on clutch/tranny?
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #2 of 10 Old 05-20-2010, 08:53 PM
Burns95
I ran my 35's for about a month with stock gears. The big difference is I had 4.10's instead of 3.07's. Its going to be a strain but would work temporarily. I went with an 8.8 swap and 4.88's. I highly recommend that setup. You could easily get away with 4.56's since you have the 4.0l. I say go for it. It will be a dog until you regear though.
Burns95 is offline
post #3 of 10 Old 05-20-2010, 08:57 PM
Sleuthhound
It will be an old dog past it's prime...are you going to be keeping the D35 or upgrading the axle too?
Sleuthhound is offline
post #4 of 10 Old 05-20-2010, 09:07 PM
MJMPC
Aint gonna be easy on the clutch.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 10 Old 05-21-2010, 06:26 AM
sloan74
Yeah man that is going to be rough....just be carefull
sloan74 is offline
post #6 of 10 Old 05-21-2010, 06:33 AM
little_Jeep
I had 3:07 gears and the 4.0L at one time in history... add the 35's and you will have a real dog on your hands. Forget trying to wheel it, you will be doing good to drive it on pavement without killing your clutch. I went with the 8.8 and 4:56 gears.... wish I had gone 4:88.
little_Jeep is offline
post #7 of 10 Old 05-21-2010, 07:48 AM
jdarg
Save enough to regear the rear axle at the same time, then don't use 4wd until you save more and regear the front to match. 4.88 is what you want, for sure.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #8 of 10 Old 05-21-2010, 08:46 AM Thread Starter
linusb
Dang...was afraId of that. My plan is to pick up an 8.8 with stock 4.10s and regear front to match...figure I can save the expense of regearing the rear.
In any case, it sounds like I need to take care of rear axle and gearing before I mount up the big 35s.
linusb is offline
post #9 of 10 Old 05-21-2010, 08:56 AM
zoomin0074
I have 33's , 4.0l, 3.07 gears.. Its a pig !! I am currently collecting parts for my 4.10 swap
94 4.0L Auto
SOA Lift on 35's
Red Jeep club #435
zoomin0074 is offline
post #10 of 10 Old 05-21-2010, 09:59 AM
little_Jeep
You could slap the 8.8 with 4:10 under the Jeep and then just drive in 2wd until you have the coin to regear both axles.
4:10's with 35's isn't great, but its a World better than 3:07's.
Stock Rubicon gears and 35's HAARUBICON TJ Wrangler Technical Forum 51 07-25-2015 10:29 PM
35's and gears, or stock and 33's reTJcon01 TJ Wrangler Technical Forum 7 04-01-2010 05:09 PM
Stock gears vs. gears for 35's RustedWrangler YJ Wrangler Technical Forum 6 08-14-2009 12:04 AM
stock gears with 35's?! bayvilleYJ TJ Wrangler Technical Forum 21 11-30-2008 11:44 PM
rubi stock gears and 35's jeep jake TJ Wrangler Technical Forum 20 07-26-2006 10:15 AM
