35, 30 fluid capacity - JeepForum.com
post #1 of 4 Old 11-18-2008, 09:53 AM Thread Starter
Isaiah17
I was wondering how much fluid the dana 35 and 30 holds. I cant find the specs any where. I appreciate it.
Isaiah17 is offline
post #2 of 4 Old 11-18-2008, 10:11 AM
jsahara24
till it starts pouring out of the drain hole... ~1.5 quarts each IIRC
99' Jeep Cherokee Sport
07' Toyota Matrix
jsahara24 is offline
post #3 of 4 Old 11-18-2008, 01:45 PM Thread Starter
Isaiah17
ya i have a solid axle diff cover and it says not to fill it to the drain hole on that cover. So about 1.5 qts in each?
Isaiah17 is offline
post #4 of 4 Old 11-18-2008, 02:18 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Taken directly from the YJ FAQ (frequently asked questions):
What fluids do I use and how much do I put in my Jeep?
*Axles:
- Gear oil - 80 weight for light duty and normally cooler climates - 90w120 weight for heavy duty and normally warmer climates Note: Some rear axles are equiped with factory posi - a limited slip additive must be put in with the gear oil to extend and protect the limited slip action
Dana 30 = 2.5 pints
Dana 35 = 3.5 pints
Dana 44 = 4.0 pints
*Engines:
- 10w30 for good general usage in most climates
- 5w30 for those colder climates (when temps are below freezing for extended periods of time)
2.5L = 4 quarts (w/ filter)
4.0L = 6 quarts (w/ filter)
4.2L = 6 quarts (w/ filter)
*Transmission (standard):
- 80 weight gear oil but most recoment Redline MT 90 to protect the interals better. 75W90 is listed by some but the 80W is just cheaper to find with no ill effects.
AX-5 = 3.3 quarts
AX-15 = 3.25 quarts
BA-10/5 = 2.45 quarts
*Transmission (automatic):
- Automatic Transmission Fluid (ATF) Dexron III
TF 904 = 4 quarts
TF 999 = 4 quarts
*Transfer case:
231 = 2.2 pints
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
Fluid Capacity hrjaw TJ Wrangler Technical Forum 9 04-22-2014 10:02 AM
Fluid Capacity wicky TJ Wrangler Technical Forum 24 03-15-2009 02:15 PM
D30/D44 Fluid Capacity sb127 TJ Wrangler Technical Forum 4 11-13-2006 12:31 PM
what is the fluid capacity of an ax-5 tranny? offdapath YJ Wrangler Technical Forum 2 05-15-2006 04:23 PM
BA-10/5 fluid capacity el guapo YJ Wrangler Technical Forum 2 06-15-2005 10:40 AM
