33x12.5x15 What wheel size?? 8" or 10" - JeepForum.com
post #1 of 9 Old 02-27-2004, 02:51 PM Thread Starter
spark plug
Heres the deal! I'm going to order black steel wheels for 33x12.5X15 and I want to get the correct size wheel and back spacing the first time. My jeep has a 3.5 bds 5/8 shackles and a 1" bl . I was going to get 15x8" wheels but the guy at the tire store really thinks I should use 15x10". Whats the correct size for this tire size? I like the crager wheels but do they give the correct back spacing for my needs?
Thanks!
"93" YJ 3.5 BDS, 5/8" Boomerings, 1"BL
33"x12.5" Ford 5.0 8.8 AX-15 231 SYE
spark plug is offline
post #2 of 9 Old 02-27-2004, 05:27 PM
Moxley
Moxley's Avatar
2017 JK Wrangler
spark plug,
The correct width rim would be 10" for 33" tires but most people don't go with those due to the wider footprint, most run 8". With 5" of total lift you should be fine with 33's on 10" rims and check with the store rep on the particular crager rim you want in regards to backspacing.
Doug
Moxley is offline
post #3 of 9 Old 02-27-2004, 05:49 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
There are numerous reasons why a 8" wheel is better suited for a 12.50 wide tire. Try a search on it.
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #4 of 9 Old 02-29-2004, 12:35 PM
TSEJEEPERS
I ran 33x12.50x15 tires on 8 inch rims for years, I never had any problems when aired down and never blew a bead. I am now running 35x12.50x15 (same width) on 10 inch rims and have blown a bead twice. If you are going to wheel it stay with 8 inch if not go with 10 inch it will make the tire look wider.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is online now
post #5 of 9 Old 02-29-2004, 06:43 PM
corst01
corst01's Avatar
Thanks!
Sometimes it depends on the make of tire.
Some manufacturers list 8" rims, while others recommend 10".
I believe the major factor is the tire contstruction itself.
Both of my YJ's and two of my other 4x4's running 33's all use 8" rims. I have never had a problem with that width.
Mind you, I have run mostly BFG MT's or AT's, and my current YJ runs Goodyear MTR's.
Check out National Tire at: http://www.natltire.com/
They have a great wheel and tire fitment chart, as well as some really good package deal pricing.
I have bought several tire and wheel packages from them and have never been disappointed yet.
Just my .02
Steve
If it aint broke... Fix it til it is!
AIM & Yahoo name: gorag65
HIS:
'88 YJ 4.2L 5spd; 4" ProComp Lift
15x8 ProLine Model 139's
33x12.5 Goodyear MTR's
Hella Rally 1000 Black Magic lights
BesTop Sunrider
Grant Signature Wheel
HERS:
'91 XJ Limited 4.0L Auto 2" Lift
31x10.5 BFG AT's
corst01 is offline
post #6 of 9 Old 03-01-2004, 07:05 AM
MY95
MY95's Avatar
Im running 33 x 13.50s on 8" rims w/ 3.5" of back spacing and have'nt had any trouble.
95 YJ 2.5L w/3.5" Superlift, 1" BL
33x13.50 Swamper LTB on 15x8 Eagle 589s
Mile Marker E12000, Optima Yellow Top
MORE 5/8" Boomerang shackles, Hi-Lift Jack
4.0 TB w/ poweraid spacer, Rustys air tube, K&N filter
WHITE Jeep club member # 007
MY95 is offline
post #7 of 9 Old 03-01-2004, 07:46 AM
bamakrw
I tried to contact crager in regards to their black rims. I was wanting to know the amount of backspacing but I never got a response. To hell with em.
bamakrw is offline
post #8 of 9 Old 03-06-2004, 05:17 PM
corst01
corst01's Avatar
I wouldn't get too concerned about the backspacing unless you're planning on wheels 10" or wider.
I believe that most 8" wheels will have similar, if not the same backspacing as the factory wheels.
Even many 10" wheels will, although that is the size that many manufacturers seem to offer different backspacings on.
Most of the time the extra width is put towards the outside if the wheel, creating the wider track. That's another reason why you will go through wheel bearings faster with wider wheels that have all the extra width just thrown towards the outside (instead of having the proper backspacing)
Just a thought from a lunatic mind.
Steve
HIS:
BesTop Sunrider
HERS:
31x10.5 BFG AT's
corst01 is offline
post #9 of 9 Old 03-06-2004, 10:47 PM
86lerado
Go for the 8" you'll get wider foot print on lower air.
J-just
E-empty
E-every
P=pocket
86 CJ-7 Laredo 4"lift 37"SSR's 30frt/44rear,3.31gears,258,auto/300t-case,caged,custom bumpers.
Wifes 92 YJ 2.5"springs,2"body,35"MTR's30f/35r,4.88gears,airlock front, locrite rear,4.0/5spd.,caged ,custom bumpers,6000'warn.
86lerado is offline
Rim Size and backspacingfor 33x12.5x15? Foreign TJ Wrangler Technical Forum 8 11-05-2009 04:32 PM
33x12.5x15 tires - How much back spacing? 4" or 3.75" Fernando YJ Wrangler Technical Forum 17 04-27-2009 04:45 PM
33X12.5X15 MT on 2.5" spacer lift? tjgrigg TJ Wrangler Technical Forum 6 02-26-2008 08:45 PM
Wheel Spacer size for 33x12.5x15 towerassoc TJ Wrangler Technical Forum 5 02-09-2006 07:30 AM
Rim size for a 33x12.5x15 richnev TJ Wrangler Technical Forum 10 02-16-2005 01:52 PM
