33x12.50 on a 7 '' rim - JeepForum.com
post #1 of 13 Old 09-21-2005, 12:50 AM Thread Starter
blevinsbulldog
I posted this on the pic thread & didnt get any hits so im trying here sence its for my yj , does anybody got any pics of 33x12.50's on a 7'' rim or better yet 33x12.50's on 95' stock Rio Grande rims. i know the will fit but i would like to see sum pics
95' RIO GRANDE
2.5 AKA THE SCREAMING HAMSTER
REAR TRACK BAR REMOVED
1 1/4 SHACKLES---3''BL
33X12.50 BFG A/T
GREEN JEEP CLUB MEMBER # 176
blevinsbulldog is offline
post #2 of 13 Old 09-21-2005, 12:58 AM
dylanking
Hmm... I don't have any pictures, but I can gaurentee that the first time you go whellin' your tires will introduce themselves to the fenders.
dylanking is offline
post #3 of 13 Old 09-21-2005, 01:02 AM Thread Starter
blevinsbulldog
i will have about 4'' of lift & tj flares , i think i should be ok for simple wheeling
95' RIO GRANDE
33X12.50 BFG A/T
post #4 of 13 Old 09-21-2005, 02:29 PM
93YJjeep
I am willing to bet you will have issues with the tire rubbing in the front really bad with the stock rim when turning. I run an 7.5-8 rim with 33x12.50s with 4 backspacing and needed to adjust the stops to keep it from hitting.
93YJjeep is offline
post #5 of 13 Old 09-21-2005, 06:56 PM Thread Starter
blevinsbulldog
oh i'm not worried about that , i can adjust my stops. i would just like to see what they look like
95' RIO GRANDE
33X12.50 BFG A/T
post #6 of 13 Old 09-21-2005, 10:37 PM Thread Starter
blevinsbulldog
the stock rims are 7'' wide aren't they ?
95' RIO GRANDE
33X12.50 BFG A/T
post #7 of 13 Old 09-22-2005, 12:46 PM Thread Starter
blevinsbulldog
----------bump
95' RIO GRANDE
33X12.50 BFG A/T
post #8 of 13 Old 09-22-2005, 04:43 PM
93YJjeep
if you adjust stops you should be fine, I have seen 33x13.50 boggers put on a stock 7" wide rim, had plently of space between the frame in the back, just makes them look like big fat donuts.
93YJjeep is offline
post #9 of 13 Old 09-23-2005, 06:30 AM
dharmabum
dharmabum's Avatar
Heres 33x12.5 BFG Mud terrains on stock 15x7 Jeep wheels on my 93 YJ with the RE XD 2.5" lift, 5/8" lift shackles, and TJ flares. I had to add a few washers behind each steering stop to keep from rubbing the springs and sway bar but it cleared the fenders fine. I ran this way for a year but have since swapped to 15x8 wheels with less backspacing.
dharmabum is offline
post #10 of 13 Old 09-23-2005, 06:23 PM Thread Starter
blevinsbulldog
THANKS SO MUCH , that's exactly what i was looking for. I'll be running the BFG A/T
95' RIO GRANDE
33X12.50 BFG A/T
post #11 of 13 Old 09-24-2005, 12:56 AM Thread Starter
blevinsbulldog
what kind of shackles are those ? i would like to get some that will give me a full 1'' lift ,can you recommend some ?
95' RIO GRANDE
33X12.50 BFG A/T
post #12 of 13 Old 09-25-2005, 08:48 PM
dharmabum
dharmabum's Avatar
In that pic they are homemade ones but I am now running the MORE boomerang shackles with 5/8" lift.
post #13 of 13 Old 09-25-2005, 09:10 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
it is the back spacing that will hurt you on the stock wheels.
i am running 35" tires on 7" beadlocks with 3.75" back spacing.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
2.5L with 4.11 and 33x12.5? iceman123187 TJ Wrangler Technical Forum 21 04-14-2008 06:26 AM
33x12.50 - What PSI do you run?? bman9089 TJ Wrangler Technical Forum 21 10-03-2007 06:25 PM
33x12.5's fit? wessy YJ Wrangler Technical Forum 5 04-22-2007 09:24 PM
33x12.50 JeepPirate TJ Wrangler Technical Forum 3 11-15-2006 11:28 PM
33x12.5? Max1775 TJ Wrangler Technical Forum 3 03-28-2006 01:59 AM
